Where to refill manual tranny fluid??
hey all,
I just drained the tranny fluid on my 2000 integra LS. Where do I refill it??? There is a little black rubber cap, with an arrow on top and a little tube comming out, is that the refill tube? How do I refill it?
You have to remove the fill bolt. It's a few inches above the drain bolt. DO NOT FILL it from that tube. You'll overfill your tranny like mad. Only fill it up to the level of the fill hole. I think http://www.c-speedracing.com may have a write up that covers this....
Here it is:
http://www.c-speedracing.com/h...d.php
Here it is:
Take the wheel off and bring the car level with the ground when filling it up, else you wont be able to fill it adequately. I use a pump adaptor that screws onto the MTF bottles coupled with an extension hose in order to reach the fill hole. There are a few different methods you can try
nfinitecc
Dec 3, 2004 03:47 PM
