what do you think about the aem C2di ignition system???
hey guys...
I´ve got the AEM Ems and the AEM wideband controller. Now I´m thinking about to buy this ignition system. Please tell me your experiences with this system.
Maybe the MSD systems are better.. What would you recommend??
Thanx for your help
Thanx for your help
yes you have to convert to DIS
i was thinking about it too.. its a good thing...theres some work involved but the outcome can be good...
someone need to do a writeup on converting...and where to get the parts...like the distributor block off thing..explain whats needed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6andslow »</TD></TR><TR><TD CLASS="quote">PM Jdogg.....he's done some work with the CDI...and can even offer you a conversion kit with everythign you need</TD></TR></TABLE>
I think he's asking $600 for the whole kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hovic »</TD></TR><TR><TD CLASS="quote">And whats about the distributor? Is it possible to remove it complete? </TD></TR></TABLE>
No, you still need the crank sensor in there unless you run an auxilary one. You can remove the coil and ICM from the distributor though. I have my 929 coils and wires and I'm waiting to find a MSD DIS-2 on ebay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salt »</TD></TR><TR><TD CLASS="quote">
No, you still need the crank sensor in there unless you run an auxilary one. You can remove the coil and ICM from the distributor though. I have my 929 coils and wires and I'm waiting to find a MSD DIS-2 on ebay.</TD></TR></TABLE>
What does it mean "unless you run an auxilary one"??
Just to let everyone know to switch to individual coils you must have a computer that will support for ignition outputs the stock computer will not do this. Also you can use a four channel and just use one of the channels to wire it in like a MSD and still use the stock distributor and coil.
What does it mean "unless you run an auxilary one"??</TD></TR></TABLE>
Some people bolt an external TDC sensor to a cam gear or crank pulley. Other people use the CAS on OBDII cars as the sensor. I think the factory one is fine and I'm going to use that one. I wanted the bling effect of a cam plug where the distributor goes, but the lack of plug wires will have to suffice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 »</TD></TR><TR><TD CLASS="quote">Just to let everyone know to switch to individual coils you must have a computer that will support for ignition outputs the stock computer will not do this.</TD></TR></TABLE>
My tuner told me i can use the Motec Ignition Expander with the stock ECU/Power FC to trigger up to 8 coils. Anyone ever tried this?
shermanyang
Sep 15, 2004 05:49 PM
