What the hell is wronge with my car?
Old Mar 26, 2004 | 09:03 AM
1BadDC2's Avatar
Default What the hell is wronge with my car?
well let me start........ all my fuses are fine. checked many times.... o maybe i am just a retard. but my dome lights dont work, my rear defroster doesnt work, my cd player and my clock works now only because i rerouted the power. but here is whats jacked up.... when i turn my cd player off the rear defroster works. when it is on it says that a door is open. meanwhile the dome lights still dont work.... wtf is wronge with my car? 97 integra ls..... incase that matters. and i only rerouted the power for the cd player to what my fog light switch gets power from. sorry i know its long
Old Mar 26, 2004 | 09:26 AM
Audi A4's Avatar
Default Re: What the hell is wronge with my car? (1BadDC2)
take it to th dealer man, u have some sort of electrical problem.. prob a shoert somewhere
Old Mar 26, 2004 | 09:41 AM
1BadDC2's Avatar
Default Re: What the hell is wronge with my car? (DRAG lll INTEGRA)
anyone else?
Old Mar 26, 2004 | 09:42 AM
JFG Kevin's Avatar
WHAT THE HELL...haha...so confusing...just take it to the dealer...unless u can clear it up....you probably wired it wrong where..so how...i dont mess with wires...unless you know what your doin...this might be worth the dealer price to check on it...
Old Mar 26, 2004 | 10:43 AM
1BadDC2's Avatar
Default Re: What the hell is wronge with my car? (aznstyler119)
need answers
Old Mar 26, 2004 | 10:47 AM
Audi A4's Avatar
UR BEST is to go the dealer or a acura speacilist. its har to dicpher whats really wrong with ur car since were not there
Old Mar 27, 2004 | 02:57 PM
SecretAznMan4u's Avatar
check your relays
Old Mar 27, 2004 | 03:13 PM
wreckedmyteg's Avatar
Check your grounds.
Old Mar 27, 2004 | 03:36 PM
Jose1995GSR's Avatar
There are also fuses under the hood...did you check all those?
Old Mar 27, 2004 | 05:01 PM
King_j's Avatar
did you buy it like this, or did you do some electrical work then notice these problems?
NotGuilty's Avatar
Default Re: What the hell is wronge with my car? (Jose1995GSR)
gwt a wired diagrahm and go from there
Old Mar 27, 2004 | 07:50 PM
m R g S r's Avatar
Default Re: What the hell is wronge with my car? (NotGuilty)
So, which is more important, the tunes or being able to see out of your rear window?
Old Mar 27, 2004 | 08:28 PM
Thrillhouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotGuilty &raquo;</TD></TR><TR><TD CLASS="quote">gwt a wired diagrahm and go from there</TD></TR></TABLE>
This guy is on the right track and I will throw in my two cents as well.
You have no blown fuses so that means you have no shorts to ground before the power load (lights or whatever), You say that one thing works when another is not working, to me this sounds like a possible cross short.
You need to get a wiring diagram and look for all the parts that arent working and trace each one separatly back to power and ground. The two things you need for each thing to start working is power and ground.
Old Mar 28, 2004 | 06:44 PM
IVI's Avatar
IVI
what kind of work was last done to the car? was a stereo system installed? it usually leads back to the last work done to the car.
Old Mar 28, 2004 | 08:02 PM
CaptainMorgan's Avatar
Default Re: What the hell is wronge with my car? (IVI)
I don't think its the problem with wiring. I have the same problem hahahaa. My dome light is out. I also notice that the light for my door is on, only with i go to radio, not cd. I don't know if my defroster works, haven't used it for months.
Old Mar 28, 2004 | 08:04 PM
TEXN3's Avatar
Default Re: What the hell is wronge with my car? (wreckedmyteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedmyteg &raquo;</TD></TR><TR><TD CLASS="quote">Check your grounds.</TD></TR></TABLE>
Old Mar 31, 2004 | 01:49 PM
Default Re: What the hell is wronge with my car? (texnteg)
I fixed my problem. It was the 7.5 amp fuse. Check that and you shoule be fine.
Peruviann
Jan 16, 2008 02:32 PM
Lucky-13
Feb 23, 2007 05:40 PM
Yoshiemaster
Honda Civic (2001 - 2005)
Aug 12, 2006 01:12 PM
PINKS
Audio / Security / Video
Jan 9, 2006 11:59 AM
gobblebox59
Nov 7, 2004 06:49 PM
