springs that i can buy with no shocks, but shocks coming later
if i plan to start off with just springs and oem struts, what springs should i buy that r safe for the stock strut
also what is a spring that also works good if i plan to get shocks later?
what r some expensive and inexpensive options that i have for this case
go with the Eibach pro kit on your stock shocks, then when you upgrade the shocks, go with the Koni yellows. they have an adjuctable perch that will allow you the option to lower an additional 1/2 inch if you wanted. that would make for a nice streetable drop with superb handling. i wish i had done this the first time around. good luck.
FYI...i had eibach sportlines with stock struts for around 2 years--without any problems. not a recommended set-up, but was fine nonetheless. not sure how low you are wanting your vehicle to be either, so take that into consideration.
so pretty much eibach is the best in this case? how muchdo u thinki will have to spend for them?
what r soem other good choice if there r any
riceforlife
Suspension & Brakes
Nov 26, 2007 02:09 PM
See Are X
Oct 18, 2003 07:53 AM
