Suspension Dumass
Old Oct 26, 2002 | 10:40 AM
slowman's Avatar
I took way too long
Default Suspension Dumass
if i get some lowering springs, will i have to get shocks to go with it. basically i want some springs that will lower my car a bit and provide a stiffer ride. if i get some springs, is that all thats needed? thanks. any spring suggestions(CHEAP)??
EDIT: like these - Springs Any good?
[Modified by slowmanEF, 1:45 PM 10/26/2002]
Old Oct 26, 2002 | 11:17 AM
GZERO's Avatar
Default Re: Suspension Dumass (slowmanEF)
if you get stiffer springs, you need better shocks, the problem is that the shocks are expensive, the springs are not that much, some good shocks are KYB AGX, Koni yellow, or tokico Ilumina. If this is for a steer driven only car they are ok, but i wouldn't recommend getting a real Coil-over setup (like tein, or zeal, or H&R). H&R springs are good, as well as the eibach (the pro-kit works fine)
But as for your questions, yeah, you need shocks or the stock shocks will only last for 5 months or so, but less than a year, and after that they blow up.
besides, shocks makes the ride, so if you don't chose shocks your ride would be harsh.
Old Oct 26, 2002 | 11:26 AM
slowman's Avatar
I took way too long
Default Re: Suspension Dumass (GZERO)
is there any way to get lowering springs but without having to get shocks? i just looked at some prices. dam! too expensive for me.
Old Oct 26, 2002 | 11:32 AM
GZERO's Avatar
well, what are we talking about, you want lower springs or stiffer ride?
if you want to lower your car, you could cut your springs (NOT RECOMMENDED), but if you want a stiffer ride, you need new springs.
if you don't have the money to do any of this, don't do it.
DON'T BE CHEAP ON YOUR SUSPENSION.
A good suspension is Eibach Pro-Kit and KYB AGX, they can be get at around 500, but there are some tokico's kit for less than that.
sorry for being the one with the bad news
Old Oct 26, 2002 | 11:38 AM
slowman's Avatar
I took way too long
ok youre right. i guess if i dont have the money to pull this off dont even bother. thanks but i guess just lowering springs would be ok. i just want the WhEeLgAp gone.
Old Oct 26, 2002 | 06:27 PM
GZERO's Avatar
and they will take your stock shocks with them, good luck anyway
Old Oct 27, 2002 | 10:09 AM
ion_four's Avatar
you can lower your car .5" - 1" without completely sacrificing your shocks. When you SLAM it, that's when your shocks die, quick.
beastman@
Oct 10, 2007 01:08 PM
white90crxhf
Suspension & Brakes
Feb 20, 2007 08:32 PM
Honda-Evolution
Nov 5, 2004 05:10 AM
victor903
Feb 20, 2003 06:28 PM
spoolinq
Jan 13, 2003 07:30 PM
