please help w/ low rpms driving w/ boost
Old Mar 26, 2004 | 08:04 AM
TurboBumblBee's Avatar
Default please help w/ low rpms driving w/ boost
i need some help tuning the car so it doesnt bog down in low rpms for a bit till i can get it on the dyno and tune it in a couple weeks. my setup is
b18c1 84mm bore 2.0ltr
stock head
drag turbo kit
rc 440
vortech fmu
aem fpr (i need fpr guage)
walbrough 255 fuel pump
vafc
stock p72 ecu
gimme a little ideas on what i need to adjust to make this car run a little better.. it tends to bog down from 1000-4000 and as soon as the turbo spools it gets to redline really fast.. it doesnt want to drive in 5th gear on the highway w/ out hesititaion. thanks for the help!
Old Mar 26, 2004 | 08:29 AM
monicle's Avatar
Default Re: please help w/ low rpms driving w/ boost (Boostfedb18c1)
are you not describing turbo lag? only things to suggest for that is open up your exhaust that will help your turbo spool a little quicker that or just get a smaller turbo.
Old Mar 26, 2004 | 08:33 AM
boosted92's Avatar
Default Re: please help w/ low rpms driving w/ boost (monicle)
So it's bogging down before you even start to boost? Maybe your FPR is set too high, try dialing that down a bit and getting a fuel pressure gauge.
Old Mar 26, 2004 | 09:44 AM
Default Re: please help w/ low rpms driving w/ boost (boosted92)
to be honest im not sure whats its doing.. ive only been in 1 fast turbo car and it was a couple years ago and it ran perfect.. i want mine to do run the same..
what do you you guys think about the vafc hack?? should i just ditch that vortech fmu and lean it out w/ my VAFC??
couple other things, remember im new to boost so im i dont know much..
last night it was blowing out a lot of smoke, im pretty sure it was dark smoke cause a friend driving behind me told me.. why was it doing that??
and also at a stop light i was getting ready to go and the whole car just felt like it was dieing, almost felt like the time when i was driving my NA civic a couple months ago and ran out of gas, the car just would not go anywhere, kept pumping and it was fine..
thanks for the help
Old Mar 26, 2004 | 09:50 AM
Johnyquest's Avatar
The hack is a world better than an FMU, and uberdata hondata is a world better than the hack. Either step is a big one. Go to ubderdata/hondata if possible, but the hack will make a world of difference.
Matt
Old Mar 26, 2004 | 09:55 AM
turbosi03's Avatar
damn that doesnt sound good. check your oil and coolant often... look under the oil cap for milkyness. I'm not one of the honda tech pro's but I'm getting pretty good at breaking things.
you should do a compression check also...
did you use a fuel pressure gauge to set the AEM fpr or what?
Old Mar 26, 2004 | 10:24 AM
IvanB's Avatar
sounds like what would happen when your turbo is too big for your engine to spool up.
What are your turbo specs.. a/r , etc.
Old Mar 26, 2004 | 10:48 AM
blown_LS's Avatar
[QUOTE=Boostfedb18c1]
rc 440
vortech fmu
QUOTE]
Ditch the fmu and run the hack with those injectors only because probably your fuel pressure is higher then a ****.
Old Mar 26, 2004 | 10:54 AM
Mr. Anderson's Avatar
From: A gas station with 87, 89, 91, 92, 93 octane, FL
you shouldn't need the fmu and the aem fpr, b/c the aem already rises the pressure when under boost. If your motor is bogging down, it could be because when you give it full throttle the afc is opening up those injectors (this all depends on what your settings are) and dumps too much fuel before the turbo has a chance to spool up.
also, on a technical note, unless you have a stroker kit, an 84mm bore alone will yield 1.9L.
Old Mar 26, 2004 | 10:57 AM
Default Re: please help w/ low rpms driving w/ boost (Got CEL)
might also try raising the low/high throttle %'s. That along with playing with your fuel curves should help.
also, what's your base fuel pressure?
Old Mar 26, 2004 | 11:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">The hack is a world better than an FMU, and uberdata hondata is a world better than the hack. Either step is a big one. Go to ubderdata/hondata if possible, but the hack will make a world of difference.
Matt</TD></TR></TABLE>
yes ive actually been researching alot today since posting this thread, im going to do the afc hack tonight! and then once i get money and do some other work to the car i will go hondata or uberdata...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">damn that doesnt sound good. check your oil and coolant often... look under the oil cap for milkyness. I'm not one of the honda tech pro's but I'm getting pretty good at breaking things.
did you use a fuel pressure gauge to set the AEM fpr or what? </TD></TR></TABLE>
the adjustable fuel pressure regulator is not on the car right now, its a stock honda regulator..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IvanB &raquo;</TD></TR><TR><TD CLASS="quote">sounds like what would happen when your turbo is too big for your engine to spool up.
i do not know the specs of the turbo, the turbo was replaced, i will get the specs on it this weekend when i can clean up the engine bay and make it look a little better!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got CEL &raquo;</TD></TR><TR><TD CLASS="quote">might also try raising the low/high throttle %'s. That along with playing with your fuel curves should help.
also, what's your base fuel pressure?</TD></TR></TABLE>
base fuel presure is stock cause the stock FPR thats on thtere.. i plan on doign the AFC hack tonight after work as shown on this site
http://www.thedropshop.tv/vafc.htm
8THGENCRUZE
Honda Civic (2006 - 2015)
Oct 25, 2013 10:49 PM
Kirk@SyndromeAuto
Feb 12, 2005 11:38 PM
eGeeHaTcH
Jan 10, 2005 09:32 PM
turboex
Aug 3, 2003 10:03 AM
slowman
Sep 3, 2002 04:53 PM
