car starts, but dies
Ive recently installed a greddy sohc kit on my d15b, the issue is when I crank the car it turns over just fine, but it then idles at like 100-200 rpms for about a min and then dies. If i press on the gas the car runs fine, I just cant sit steal or i have to keep pressing the gas for it to remain running. Whats goin on???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mi4dc5 »</TD></TR><TR><TD CLASS="quote">I had the same problem. Check your injectors. You might be running to lean. </TD></TR></TABLE>
how do youcheck your injectors, or how do you know if it running lean/rich without a gauge.
After further investigation, heres whats going on. When you crank the car, it turns over. But when you apply some gas you feel the motor stumbling the whole time, and when you let off the gas it idles at like 200 rpms and eventually dies out. Please help guys, this is getting so frustrating
this happend to me. I had one bad injector and a leak at my wastegate and a bad map chip. I replaced the map chip with a missing link, fixed the injector and still havent gotten a new wastegate
It idles a little better now.
4_door_teg
Oct 25, 2004 05:18 PM
