ignition timing..
Old Mar 25, 2004 | 06:13 PM
bOOsTiNSoHcVtEc's Avatar
Default ignition timing..
Checked my friends timing on his b18b and it seems like his timing was retarded at like 12 degrees...which probably contributed to his low trap a few weeks ago at the track. So I advanced it to 16 but then after we finished I check it again and it looks like 15-15.5. The lines are kinda hard to see and its kind of hard to line it up with the arrow cause if you move your head it looks different. How do you really know your timing is accurate?? And do you really need to jump the service connector? What is the purpose of this? We didnt...hope that didnt effect anything. Also for you b18b guys what timing felt good on your car?
Old Mar 25, 2004 | 06:19 PM
mmuller's Avatar
Mad Scientist
Default Re: ignition timing.. (bOOsTiNSoHcVtEc)
you have to jump the service connector to set base timing since if the service connector is not jumped then the ecu changes timing
Old Mar 25, 2004 | 07:33 PM
Default Re: ignition timing.. (mmuller)
So since i didnt jump the service connector you think the timing isnt actually what I set it as according to the crank pulley? The ecu wouldnt set it back to stock settings at 16 degrees? Cause really thats all I want to do. How would i correct the timing since the ecu has taken over? Just jump the service connector and use the crank pulley and distributor again?
Old Mar 26, 2004 | 05:23 AM
EE_Chris's Avatar
Shorting of the service connector disables the ECU from being able to advance or retard the timing while your trying to set it.
Old Mar 26, 2004 | 06:20 AM
MightyMouseTech's Avatar
Default Re: ignition timing.. (EE_Chris)
If you let the car fully warm up (fans have come on at least twice) shorting the service connector will only make a 0.5-1 deg difference, if it makes a difference at all.
Old Mar 26, 2004 | 08:08 AM
Default Re: ignition timing.. (MightyMouseTech)
i kinda figured...cause i have 2 friends that are honda techs and they never jump the connector when they do timing. But also how do you guys really know if its accurate? or do you guys dont know?
Old Mar 26, 2004 | 08:44 AM
IN VTEC's Avatar
When you're looking down at the pointer, you have to use a POV that allows you to only see the triangle on the top of the pointer. If you can see the faces of the pointer sides, then you're looking at it crooked.
fastrat37
Dec 24, 2012 03:49 PM
turbo-crx
May 18, 2008 02:13 PM
civic j
Aug 17, 2007 08:10 AM
EKB18BPR3
Nov 30, 2003 10:36 AM
dubnine
Sep 16, 2002 01:35 PM
