TPS Pin Location
Old Mar 25, 2004 | 05:54 PM
iHave2Cams's Avatar
Default TPS Pin Location
does anyone know the correct plug and wire for the tps sensor on a 92 civic 4 door ???
Old Mar 25, 2004 | 06:22 PM
rtype11's Avatar
Default Re: TPS Pin Location (iHave2Cams)
its three wires and you can trace it with a multimeter and using the colors??????????
it goes to the smallest plug that goes into your ECU should narrow it down to about 10 wires.
Old Mar 25, 2004 | 06:35 PM
iHave2Cams's Avatar
Default Re: TPS Pin Location (rtype11)
well, im putting a zex kit on my car and i dont know which of the 3 wires i have to hook the control unit to....can anyone help
Old Mar 25, 2004 | 06:56 PM
im_poor's Avatar
doesn't the kit come with instructions?
Old Mar 25, 2004 | 09:26 PM
iHave2Cams's Avatar
Default Re: TPS Pin Location (im_poor)
no its a used kit
Old Mar 26, 2004 | 03:46 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHave2Cams &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know the correct plug and wire for the tps sensor on a 92 civic 4 door ???</TD></TR></TABLE>
yel/wht is +5v
pnk/blk is sensor input
grn/wht is ground
Old Mar 26, 2004 | 07:45 AM
iHave2Cams's Avatar
Default Re: TPS Pin Location (Chiovnidca)
thanks man i appriciate it
Old Mar 26, 2004 | 11:29 AM
tgreaves's Avatar
Its the middle wire on the plug..
Jeremy Harr
Feb 10, 2017 07:00 PM
raider1qaz
Feb 13, 2013 12:14 PM
turbo-crx
Sep 30, 2008 10:00 AM
jwbnavy
Dec 4, 2007 02:20 PM
lumpylude
Oct 28, 2007 06:11 AM
