Coolant temp sensor wire cut!
Well i changed my head gasket on my 1996 honda civic last week and accidentally pulled to hard on the Coolant temp sensor that's under the distributor and wires got disconnected, and i cant just tape them together because the wires got yanked out of the plug.Any advice??
talks to himself
Re: Coolant temp sensor wire cut!
Search on here about re-pinning plugs and try to re-pin it.
Or, go to a junk yard, cut a plug off another 6th gen civic, and swap your de-pinned plug out. All it takes is a wire cutter, wire stripper, solder, flux, heat tape, and a soldering gun.
going to a pick n pull is a lot easier than trying to re-pin and solder(trust me) i ripped my vss plug apart so i went to the yard and found one. then taped the wires toghter(after stripping them back 2 inches) workd fine to this day.
Same exact thing happened to me and I took the plug to my friendly neighborhood Honda dealership and the parts guy disassembled the plug at the counter, went in the back and came out with new pins for the plug (even gave me extras). No charge.
Took everything home and some wire strippers and a few crimps later my plug was like new again.
The plug will stubbornly come apart if you pry at the rubber inside piece for a bit with a very small screwdriver. Something to do while you're watching TV.
carpenterkyle
11-03-2012 07:45 PM
jwbnavy
12-04-2007 02:20 PM
SPORT INJECTION
06-27-2003 10:48 AM
