Any have this one seize on them?
Old Mar 25, 2004 | 11:29 AM
Liquidgsr's Avatar
Default Any have this one seize on them?
The front fork bolt that goes through the fork with a bushing on it that needs to be take out in order to drop the shock and spring assembly down. Mine wont budge. If how have you take it out. I know a lot of people just use a breaker bar and hammer it, but in my case it wont turn at all. So any ideas?
Old Mar 25, 2004 | 11:34 AM
FlaN.'s Avatar
Default Re: Any have this one seize on them? (Liquidgsr)
haha, everyone has a problem with that bolt! I took a breaker bar and a long pipe to it after spraying numerous coats of PB Blaster on it. it worked
Old Mar 25, 2004 | 11:48 AM
MightyMouseTech's Avatar
What usually happens is the bolt seizes in the bushing. Time to get out the torches and cut out the bolt and then replace the bushing. Just be careful not to torch the CV boot.
Old Mar 25, 2004 | 12:25 PM
Liquidgsr's Avatar
Default Re: Any have this one seize on them? (MightyMouseTech)
ok now how hard is it to put a new one in...cuz thats what im really worried about. Im about to go to the automotives store and get some PB blaster...hoping it will work.
Old Mar 25, 2004 | 12:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">ok now how hard is it to put a new one in...cuz thats what im really worried about. Im about to go to the automotives store and get some PB blaster...hoping it will work.</TD></TR></TABLE>
To be honest, if you are asking me how hard it is to do, you may want to take it to a shop to do. I hate doing them myself. If you can get the lower arm off, you can use a press to change the bushing after you have cut off the bolt. If you can't get the arm off (seized inner bolt, don't feel like replacing end links) then you will probably need a air chisel (I use a modified sheet metal cutter bit to get the shell out without damaging the arm) to get the old bushing out. To get the new bushing in, use lots of silicone grease and a bushing driver and pound away at it. Unless you can get the arm off, in which case you just use a press to get the bushing in.
Sounds like fun don't it?
This is deff one of my least favorite jobs, I had to do a set yesterday and I can still smell the burnt rubber in the shop....
Old Mar 25, 2004 | 01:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I've never had a problem with the front fork bolts, on my car or anybody elses. Usually it's the rear LCA bolts that are a b!#ch (although I've never had a problem with those on my car either *knock on wood* ). one time one of my top fork pinch bolts tried to strip itself before I had the shock fully seated in the fork, but a quick once-over w/ a tap and die cleaned that right up.
Old Mar 25, 2004 | 01:13 PM
Default Re: Any have this one seize on them? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I've never had a problem with the front fork bolts, on my car or anybody elses. Usually it's the rear LCA bolts that are a b!#ch (although I've never had a problem with those on my car either *knock on wood* ). one time one of my top fork pinch bolts tried to strip itself before I had the shock fully seated in the fork, but a quick once-over w/ a tap and die cleaned that right up. </TD></TR></TABLE>
I wish. You obviously don't live in an area where they use salt in the winter. I have seen two year old cars with seized bolts.
Old Mar 25, 2004 | 01:23 PM
Liquidgsr's Avatar
well i just sprayed a coat of rust buster on it and i will see what that does for it. Crossing my fingers.
Old Mar 25, 2004 | 01:31 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">
I wish. You obviously don't live in an area where they use salt in the winter. I have seen two year old cars with seized bolts.</TD></TR></TABLE>
Nope, my car has spent it's life in TN, GA, and MS.
Old Mar 25, 2004 | 01:32 PM
Liquidgsr's Avatar
bastard ***...haha my car has the worst luck with anything possible. Freakin thing has problems i hate it but love it. DAMN GSR.
sonny0330
May 29, 2008 06:53 AM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
dukers
Nov 14, 2004 12:36 AM
type Gendy
22
Apr 1, 2004 11:29 AM
turbotime
Jun 19, 2003 09:58 PM
