94 Integra GSR Rear Disc bolts onto CRX?
I looked far and near in the archives. Deep deep deep. Couldn't find any solid confirmation that the 94-01 Integra Rear discs will indeed bolt on. I'm planning on picking up a 94 integra gsr rear disc setup with trailing arm and I do not want to blow $200 bucks on it and not have it fit on my 88 crx si.
Will 94 Integra GSR rear discs with trailing arm bolt onto a 88 CRX Si?
This was the best thread I can find:
https://honda-tech.com/zerothread?id=399168
Everywhere else states 90-91 CRX si discs or 90-93 da discs. No confirmation on other setups such as 94-01 integra or civic si.
You should have no problems. People usually use 94+ GSR rear disc's on EG's and a friend of mine used EG rear disc's on his EF. So thats like if A=B and B=C, then A must equal C...right? So yea it should work perfectly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">i'VE GOT 90=91 crx sI EBRAKE CABLES ALREADY. i AM WONDERING ABOUT THE BRAKES AND TRAILING ARM. </TD></TR></TABLE>
lmao, perfect example of hitting the caps lock instead of the shift button when you start typing, and not looking before you post it. Classic.
i have 96 GSR's on my hand, but i haven't put them on yet, haven't had time and its been sitting in my garage for almost a year now. lol..
but yeah, i was told it will fit with a little modification of the e-brake lines, because it won't bolt up to the factory locatoin, i think it was too long or something lik ethat.
yeah, for sure they will fit. just make sure you use 90-91 CRX Si ebrake cables. also use all your CRX arms back there, none of the integra ones (compensator arm, upper arm, lower arm).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumGTR »</TD></TR><TR><TD CLASS="quote">yeah, for sure they will fit. just make sure you use 90-91 CRX Si ebrake cables. also use all your CRX arms back there, none of the integra ones (compensator arm, upper arm, lower arm).</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">i used the complete suspension from a my 90 LS for my civic and it was fine...you can use all the arms it just made my car about an inch lower</TD></TR></TABLE>
no! your toe and camber will be altered if you use any arms other than the CRXs (c-arm and lca to name two).
TNight
Jan 13, 2014 07:28 PM
RPM_69
Sep 29, 2007 10:50 AM
pac_crx
Jul 15, 2006 05:53 PM
