OBDII JDM p72 auto to manual ecu conversion possible?
Old Mar 24, 2004 | 10:22 PM
XES's Avatar
XES
Default OBDII JDM p72 auto to manual ecu conversion possible?
I am wondering if it is possible to convert a OBDII jdm p72 ecu that is automatic to manual. Usually with the OBDI jdm ecu's you can just switch the resistance of the RP18 resistor from 2.4 to 1.4k ohms. This ecu does not have RP18 located anywhere on it. Just as a reminder, this ecu is the same size as a USDM ecu, but it has surface mounted chips, etc.
Does anyone know what needs to be changed, etc. for this to be changed into a manual ecu?
Old Mar 24, 2004 | 11:54 PM
RedZone's Avatar
Default Re: OBDII JDM p72 auto to manual ecu conversion possible? (XES)
as far as I know it has not been done yet, I will search more on the subject and let you know......katman might know he is on H-T...hit him up
Old Aug 2, 2004 | 08:46 PM
dave_ed9's Avatar
i'd like to know the answer to this too, if anyone knows..
Old Aug 3, 2004 | 02:19 AM
Fobtions's Avatar
Default Re: OBDII JDM p72 auto to manual ecu conversion possible? (dave_ed9)
obdII ecu's are pretty much non tamperable, the cost of the equipment to modify would make switching to a obd1 ecu cheap .
stiffinEK
Apr 28, 2011 10:49 PM
I CRX I
Engine Management and Tuning
Feb 18, 2010 08:09 PM
SkyLinER
Nov 8, 2004 05:58 PM
integra_gsr98
Jun 10, 2003 08:42 PM
