What 14 inch rim fits over Integra disc brakes?
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Will stock 88 crx si rims fit? What about 14 inch steelies?</TD></TR></TABLE>
91 si wheels will not fit...i assume 88 would be the same dimensions.
i have some 14" alloys from a miata that fit with a 1/8" spacer...
14" steelies should work, cause i think that is what is on integras anyways.
I had 14inch civic HX rims and they didnt fit over integra disc brakes unless you got a spacer(easily bought from pepboys). Just get a spacer and you can run the Si wheels. I think they are only like 20-40 bucks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 »</TD></TR><TR><TD CLASS="quote">91 si wheels will not fit...i assume 88 would be the same dimensions.</TD></TR></TABLE>
The si rims DO fit. I have done this personally. The clearance between the spokes in the rim and the caliper are CLOSE, oh so close though.
You sir are wrong.
The 88 crx si wheels will rub on the caliper. I know because I had them on my crx before the swap and tried to put them on after the swap and they do not fit correctly.
The 91 si rims that went onto the da brakes, fit. How can I be wrong when I already said I have done this personally? I'm not calling you wrong, but don't tell me about my experiences please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1st-hybrid »</TD></TR><TR><TD CLASS="quote">You sir are wrong.
The 88 crx si wheels will rub on the caliper. I know because I had them on my crx before the swap and tried to put them on after the swap and they do not fit correctly.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough »</TD></TR><TR><TD CLASS="quote">The 91 si rims that went onto the da brakes, fit. How can I be wrong when I already said I have done this personally? I'm not calling you wrong, but don't tell me about my experiences please.
Are the 88Si and 90si rims a little different or exactly the same?
I don't know if they are the same or not.
What I do know is the 88 si wheels I have sitting on my back porch because they did not fit, don't fit. I don't know if notfastenough has "special" si wheels or newer ones that are a bit bigger, but the 88 si wheels were dragging on my calipers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">I THINK that 14" steelies would.
reason:
94 exa civic coupes had 14" steelies, and
the brakes are the same size as the Integra.
same size yes, but different size calipers. Why not just shave the caliper? I've seen pics somewhere on here where they shaved the caliper and it was close, very close but worked.
reason:
</TD></TR></TABLE>same size yes, but different size calipers. Why not just shave the caliper? I've seen pics somewhere on here where they shaved the caliper and it was close, very close but worked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">The Si wheels are different from 88-89 and 90-91. Do we need to post up pics? </TD></TR></TABLE>
he is right. the 88-89 Si wheels are called ripsaws or something, and i dont know what 90-91's are called. totally different pattern.
spunautosports
Nov 2, 2006 06:58 PM
PhatBoy5015
Oct 18, 2005 11:09 PM
RedheadRacing
16
Jan 30, 2004 12:12 PM
