Integra Front Brakes with stock 14" rims?
I have a 97 Civic HX with the stock 14" alloy rims (not the steel wheels with hubcaps). I was wondering if i changed the front brakes to regular Integra front brakes if the rotor and caliper would fit with the stock rims.
As long as I dont have to take out any more Metal Gears
Re: Integra Front Brakes with stock 14" rims? (PhatBoy5015)
its weird, the integra brakes with fit with 14" steelies, but it wont fit the HX wheels. U have 2 options to use those wheels with integra brakes: Either put some spacers on, or grind down the side of the cailper a little bit. Do a little searching and u will find a DIY. I saw one last week, but i forget which forum it was in
Re: Integra Front Brakes with stock 14" rims? (Phantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phantastic »</TD></TR><TR><TD CLASS="quote">i used wheel spacers and everything worked out great.</TD></TR></TABLE>
you can get spacers in different sizes...if you get a spacer that is too big then yeah it would go pat the fender..but you would not even be able to get the wheel secure since the studs would probably be too short
