i need help with the wiring a disszy
Old Mar 24, 2004 | 06:13 PM
civc 91's Avatar
Default i need help with the wiring a disszy
i have a crx and i put in a d16z6 and the last thing i have to do is how to wirer up the dizzy cus it is obd 1 and i was try a long time to make it work if someone out there can help ,or have a pinout to wire it thank
Old Mar 24, 2004 | 06:22 PM
Redline130's Avatar
Default Re: i need help with the wiring a disszy (civc 91)
Are you using the P28 ecu, or an OBD0 ecu?
Old Mar 24, 2004 | 07:10 PM
civc 91's Avatar
Default Re: i need help with the wiring a disszy (Redline130)
pr4 obd 0
Old Mar 24, 2004 | 07:16 PM
Redline130's Avatar
You will have to use an OBD0 distributor since you are using an OBD0 ecu.
Old Mar 24, 2004 | 07:29 PM
civc 91's Avatar
what kind can i distrbutor can use
Old Mar 24, 2004 | 09:12 PM
Redline130's Avatar
No OBD0 distributor will bolt up perfectly to the z6 head. You can use a 88-91 Si distributor, but you will need to cut the front mounting leg off, and modify the top mounting hole.
Old Mar 24, 2004 | 09:26 PM
civc 91's Avatar
ok thank i'll try that i'll let you know what happen thank again
Old Mar 24, 2004 | 09:29 PM
Redline130's Avatar
Yeah, no problem...if you run into any snags along the way, just PM or email me. Glad to help.
thirteen20CRXSi
Nov 15, 2008 08:25 AM
89hatcher
Jun 5, 2006 02:01 AM
crxjay
Jul 8, 2004 03:04 PM
soundman
May 8, 2003 06:38 AM
Sirex
Mar 18, 2003 07:31 PM
