vtec not engaging? car rattles a bit
Old Mar 24, 2004 | 06:08 PM
ensracer's Avatar
Default vtec not engaging? car rattles a bit
i ran vtec wire direct and it turns on and i checked the screen on solenoid and that works. with the car at idle i hit the vtec wire to power and it stalls the car and thats fine but when running i lean on it slowly and nothing happens it does not engage. i am running a chipped p72 and i also tryied out my friends p28 and the oil level is ok. ????????what else should i try
11:8 1 compression ported polish, spring and retainer
Old Mar 24, 2004 | 06:16 PM
Cottonwoodz's Avatar
Default Re: vtec not engaging? car rattles a bit (eduardo)
You need to be moveing 19Mph+ for Vtec to engage..............
Plus more then 1/2 throttle
Old Mar 24, 2004 | 06:18 PM
ensracer's Avatar
Default Re: vtec not engaging? car rattles a bit (Cottonwoodz)
yea for sure ive tryied it in every gear and steping on the gas
Old Mar 24, 2004 | 07:43 PM
98 blacksh's Avatar
y 19 mph? never heard of that
Old Mar 24, 2004 | 08:10 PM
Default Re: vtec not engaging? car rattles a bit (98 blacksh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 blacksh &raquo;</TD></TR><TR><TD CLASS="quote">y 19 mph? never heard of that</TD></TR></TABLE>
Yes 19 Mph
Old Mar 25, 2004 | 10:27 AM
prelittlelude's Avatar
yup, says so i think in the helms,
well make sure that you have everything wired up correctly, and maybe try a stock p13, who ever chipped you ecu could have done it wrong, or the program isn't right
bad_bwoy007
13
Oct 26, 2009 02:21 PM
onesixteen
Feb 20, 2008 08:11 AM
UnderConstruct95ex
16
Jan 31, 2007 06:22 AM
lsvteccivic
Oct 18, 2006 04:17 PM
