Help on installing a Tranny.
Old Mar 24, 2004 | 04:17 PM
civicgsr6991's Avatar
Default Help on installing a Tranny.
I plan on installing a tranny on my gsr engine. But I was wondering what gaskets and seals will I need to do this? Part Number etc. HELP
Old Mar 24, 2004 | 04:28 PM
MyBigNut's Avatar
Default Re: Help on installing a Tranny. (civicgsr6991)
with the info you've provided... none.
Old Mar 24, 2004 | 04:41 PM
SPLNRSX's Avatar
Default Re: Help on installing a Tranny. (MyBigNut)
none if your'e just putting it in
Old Mar 24, 2004 | 07:55 PM
Its not new thats why I ask what seals should I replaced?
Old Mar 24, 2004 | 08:10 PM
VTECorona's Avatar
You should have asked in the tech forum. A mod will probably move it for you when he gets to it.
Old Mar 24, 2004 | 08:59 PM
OTOKOTO-TSOI's Avatar
do u know how much miles is it? did u know that the one u r going to put in is not grinding? But I suggest get synthetic oil with when u put it together.
Old Mar 24, 2004 | 11:45 PM
B2FiNiTY's Avatar
If there is no grinding or anything wrong with it, there is no need to open it up. There are only 2 seals you need to worry about they are the oil seals/axle seals. 2 on each side. Not very expensive and easy to replace provided you have the tranny opened up.
Old Mar 25, 2004 | 05:40 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Help on installing a Tranny. (OTOKOTO-TSOI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTOKOTO-TSOI &raquo;</TD></TR><TR><TD CLASS="quote">do u know how much miles is it? did u know that the one u r going to put in is not grinding? But I suggest get synthetic oil with when u put it together.
synthetic oil no-no for a transmission
Honda MTF
GM or Pennzoil Synchromesh
Old Mar 25, 2004 | 05:57 AM
tilt's Avatar
Default Re: Help on installing a Tranny. (PatrickGSR94)
ive had good results with redline mtl - it's synthetic oil with friction modifier. but in general yes, synthetic is bad... too slippery for them synchro bishes.
Project_EK
Jul 14, 2008 07:42 PM
ghost_ryder35
21
Sep 21, 2005 09:06 PM
95civic_b20turbo
Jun 12, 2005 06:31 PM
Tegra
Oct 2, 2002 09:37 PM
Skiller
Sep 30, 2002 03:49 PM
