putting type R cams into a GSR
yeah i was wondering what u need to change to put the cams in, if anyone has done this i need ur help, i have heard people say u need to replace the springs and then i call and there is inner and outer springs for the exhaust side and the intake side and im just a little confused so any help will be real appreciated.
WELCOME TO H-T!!!
i hate to be a "search *****" but seriously...
i went to search-- did an ARCHIVED search in INTEGRA- for 'ITR cams', and i got 140+ matches!!!
all the info you need is already here man
for your question-- go ahead and dump the cams in-- just dont go over the factory redline!!
im running ITR cams on factory GS-R springs/retainers-- just dont raise your rev limit
As mentioned, your engine will be safe as long as you stick with the stock revlimit. It would pay to save the extra for the R valvetrain for added safety and for getting the most out of the cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra »</TD></TR><TR><TD CLASS="quote">get them tuned are they are very nice!!
those cams, and jdm itr header gained me 16hp with minor V-AFC tuning!
How much whp did you dyno at? So itr cams, jdm itr header, 2.5 cat/testpipe, exhaust, and vafc right?
</TD></TR></TABLE>How much whp did you dyno at? So itr cams, jdm itr header, 2.5 cat/testpipe, exhaust, and vafc right?
my gs-r with AEM short ram intake, and RS*R catback dynoed 152whp.
the addition of '01 ITR cams, '98 JDM ITR header, 2.5 carsound, and V-AFC dynoed at 168whp.
From: Formerly of SF moved to DFW and now back in SF, CA, USA
I ran the CTR cams for 6 mos prior to tuning. And then after it was tuned I still didn't upgrade the valvetrain. You don't have to unless you raise the stock 8100 rev limiter, which I didn't do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gee3 »</TD></TR><TR><TD CLASS="quote">I ran the CTR cams for 6 mos prior to tuning. And then after it was tuned I still didn't upgrade the valvetrain. You don't have to unless you raise the stock 8100 rev limiter, which I didn't do.</TD></TR></TABLE>
so how long have you been running the CTR cams with stock valvetrain?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">when putting itr cams in the gsr
move the stock intake valve springs to the exhaust side
and buy some new itr intake valve springs</TD></TR></TABLE>
Ill keep that in mind. Are the itr intake valve springs colored orange or blue?
Are itr retainers any different from the gsr?
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96gsr4dr »</TD></TR><TR><TD CLASS="quote">
so how long have you been running the CTR cams with stock valvetrain? </TD></TR></TABLE>
i don't know about him, but i've been running perfect for 1.5 years so far, at least 15,000 miles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [TODA R »</TD></TR><TR><TD CLASS="quote"> 2000]
Yellow, All b-series retainer are the same.
Upgrading to Titanium retainers for ANY SETUP running on the street is useless, even if you are runnning big cams.
I JUST purchased a full set of itr valve springs are retainers off H-T (still in the mail), and was just curious about the retainer comment. Will stock b-series retainers be okay with itr cams and valve springs if revving to 8500 rpms??? or should the valves get changed also........
BoostedVtecGsr
Nov 3, 2004 08:10 AM
