Installing pistons...a question
Old Mar 24, 2004 | 01:41 PM
ScootinIntegra's Avatar
Default Installing pistons...a question
Do i need to lube the sides of my pistons or the cylinder walls when reinstalling my pistons? i.e with assembly lube.
Old Mar 24, 2004 | 01:50 PM
IN VTEC's Avatar
Default Re: Installing pistons...a question (ScootinIntegra)
Just oil. 30W or 10W-30.
Don't ever put assy lube in the bores.
Old Mar 24, 2004 | 03:59 PM
Default Re: Installing pistons...a question (IN VTEC)
thanks
Old Mar 24, 2004 | 06:55 PM
deepgreengsr's Avatar
dont even put OIL!! unless you want your car to smoke forever. Leave them dry and the rings will seat and no smoke.
Old Mar 24, 2004 | 06:56 PM
eghonda's Avatar
Default Re: Installing pistons...a question (deepgreengsr)
i used wd-40 to coat the skirts
Old Mar 24, 2004 | 07:30 PM
ChillOutWayne's Avatar
Default Re: Installing pistons...a question (eghonda)
i put a small amount of oil on the top of the piston, then cranked it by hand up and down to coat the walls and such, then got all the excess off the top of the piston. good luck
Old Mar 24, 2004 | 10:03 PM
dannylDAsport's Avatar
use nothing, just install, run the **** out of it to set rings for 15-30min, and then oil change it.
Old Mar 24, 2004 | 10:21 PM
garados's Avatar
I was told to massage (work the oil in with your fingers) the walls with dino-oil before installing the pistons. I kept the walls oiled throughout the rebuilding process. I have had no problems with the engine smoking or anything. FWIW, I used honda 5w30 oil.
soon2bdropped
Sep 28, 2007 09:43 AM
EKB18BPR3
Jul 4, 2007 04:54 PM
jtracing919
Jan 25, 2006 05:06 PM
crx1856
Sep 18, 2003 02:34 AM
lopey
Feb 5, 2002 09:46 AM
