code 6
Old Mar 24, 2004 | 11:32 AM
ThaReason's Avatar
Default code 6
Ok here is the problem. My check engine light came on so i pulled the code and it was code 6, so i went and bought a brand new sensor and its still giving off the same code. Is it in my wiring or is it my ECU. I have a 97 Integra with ls/vtec, and i am running a JUN chipped p28 and a obd-2 to obd-1 jumper pack. Can anybody help me.
Old Mar 26, 2004 | 12:57 PM
ThaReason's Avatar
Default Re: code 6 (ThaReason)
bump
Old Mar 26, 2004 | 04:20 PM
SprayinCX's Avatar
well try a different ecu one that you know works and go from there. it could also be your conversion harness is pinned wrong or a loose wire maybe even a shorted out wire?
Old Mar 26, 2004 | 05:20 PM
ThaReason's Avatar
ok thanks for the info, i want be able to check until like monday or tuesday but ill let u know if it works
91 DA Revived
Aug 22, 2010 10:34 AM
slo97coupe
Apr 3, 2006 10:26 PM
civic-4-ges
Jan 24, 2004 08:28 AM
