not over 3000 rpms!
Old Mar 24, 2004 | 10:32 AM
acc97lxAndy's Avatar
Default not over 3000 rpms!
Yes my accord won't go over 3000 rpm's when i press the gas pedal or while driving it. it is like if it is cutting fuel or something but can figure this out. is it a sensor or something like it?
Old Mar 24, 2004 | 10:36 AM
.bagged's Avatar
Default Re: not over 3000 rpms! (acc97lxAndy)
Could be fuel or you might wanna check your spark plugs too
Old Mar 24, 2004 | 10:42 AM
Riceburner247's Avatar
Default Re: not over 3000 rpms! (baGged93aCcord)
You're not revving it in neutral, are you? I know the new accords won't let you past 3k or something like that.
Is acceleration smooth up to 3k? Do you notice any stuttering or bucking?
Old Mar 24, 2004 | 11:19 AM
It's a 97 and it din't use to do that. only after we intalled the block of a prelude 93. and to do that we remove the tranny and engine because i replaced the tranny too.
Old Mar 24, 2004 | 12:25 PM
Default Re: (acc97lxAndy)
I would double check all your connections. You might not have connected everything after you installed the motor.
Old Mar 24, 2004 | 01:29 PM
TOAB's Avatar
maybe something with fuel or the throttle position sensor?
Old Mar 27, 2004 | 03:52 AM
no it's not an auto? but i found the problem the crankshaft sensor that is located close to the oil pump pulley was not receiving the right timing brcause the gear had a piece broken
Old Mar 27, 2004 | 04:58 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acc97lxAndy &raquo;</TD></TR><TR><TD CLASS="quote">It's a 97 and it din't use to do that. only after we intalled the block of a prelude 93. and to do that we remove the tranny and engine because i replaced the tranny too.</TD></TR></TABLE>
Didn't get the MAP and TP sensor conectors mixed up did you?
Old Mar 27, 2004 | 03:44 PM
StimpyBoy's Avatar
Default Re: (Chiovnidca)
You don't have any CEL codes right? It almost sounds like the ECU is in safe mode...
Old Mar 28, 2004 | 11:30 AM
why do you think that i got the MAP and the TP sensors mixed up/
Old Mar 28, 2004 | 11:51 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acc97lxAndy &raquo;</TD></TR><TR><TD CLASS="quote">why do you think that i got the MAP and the TP sensors mixed up/</TD></TR></TABLE>
They don't run very well that way. Were they?
Atomic Ant
Oct 16, 2017 11:01 PM
AC01R1
Jun 24, 2009 10:42 AM
garfunkle55
Jun 14, 2007 10:26 PM
AMG
Nov 5, 2005 02:08 PM
One Slow Lude
Feb 13, 2003 01:57 PM
