got a code 10, IAT replaced the sensor,.....
91 accord lx coupe 5 speed ...
got running after a lot if issues ...
drove it 325 miles and the gas tank had crap in it which required the installation a second fuel pump..
Original codes after replacing the main relay and fuel pump were the TDC sensor and the ignition sensor in the distributor..
Gently used distributor from a junk yard..
its runs... Yeah soon its chugging and problems 2nd fuel pump and filter
the injectors were cleaned tested and new seals plugs wires
only thing I can think of is the fuel presurre regulator... or the fuel pump is bad again.
When U start it will drive fine .. then it will bog down upon acceleration and back fire and die...
turn of the key and then back on again it will drive fine for a few min .. the bog down when U step on the gas...
Clogged EGR .. Catalytic...ECU...???
I removed the sensor to allow the back pressure in the cat to build and see if it gets hot...
Check my fuel pressue with a gauge..
Last thing is to drill out the plugs and clean out the ports and install new plugs
BTW the ONLY thing i have not messed with is the Throttle Positioning Sensor...
