D16Z6 or D16Y8 Tranny
Old Mar 24, 2004 | 06:32 AM
ME SO FST's Avatar
Default D16Z6 or D16Y8 Tranny
Is there any differents in these trannys? I looking to get another tranny and wonder which would be the stronger tranny. Or if you have any other ideas that might fit a d series motor.
I am looking to be able to hit good speeds on the highway but not to KILL me 1/4 time.
Old Mar 24, 2004 | 06:39 AM
Echo7847's Avatar
Default Re: D16Z6 or D16Y8 Tranny (ME SO FST)
The Y8 has stronger shift forks, but otherwise theyre pretty much the same.
Old Mar 24, 2004 | 06:42 AM
mooseknuckle's Avatar
y8, its newer.
Old Mar 24, 2004 | 07:48 AM
95cxhatch's Avatar
Default Re: D16Z6 or D16Y8 Tranny (mooseknuckle)
yes it is a better and newer tranny , as said b4 it has stronger shift forks...they steel compared to aluminum that the Z6 has!!!!
Old Mar 24, 2004 | 08:41 AM
RyanEJ8's Avatar
Default Re: D16Z6 or D16Y8 Tranny (95cxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxhatch &raquo;</TD></TR><TR><TD CLASS="quote">yes it is a better and newer tranny , as said b4 it has stronger shift forks...they steel compared to aluminum that the Z6 has!!!!</TD></TR></TABLE>
Old Mar 24, 2004 | 09:20 AM
nichols_si's Avatar
so if i have a d16z6 i can bolt on a y8 trannie in replace of the z6?
y8 stronger for early syncro wear?
Old Mar 24, 2004 | 09:21 AM
Targa250R's Avatar
be professional
Default Re: (nichols_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nichols_si &raquo;</TD></TR><TR><TD CLASS="quote">so if i have a d16z6 i can bolt on a y8 trannie in replace of the z6?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">y8 stronger for early syncro wear?</TD></TR></TABLE>
No.
Old Mar 24, 2004 | 09:24 AM
2FastxEg's Avatar
yeah my z6 tranny is geting shitty pretty quick..
Old Mar 24, 2004 | 10:47 AM
nichols_si's Avatar
any re locating or fabing required
for a y8 to take bolt up to my z6 engine in my eg HB?
Old Mar 24, 2004 | 10:51 AM
allmotaeg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nichols_si &raquo;</TD></TR><TR><TD CLASS="quote">any re locating or fabing required
for a y8 to take bolt up to my z6 engine in my eg HB?</TD></TR></TABLE>
no relocating or fabbing required just bolt it up fill it up with fluid and go
Old Mar 24, 2004 | 10:52 AM
SloCivicHMM's Avatar
bolts right up!!
you need to reuse the reverse sensor off the z6 since the plugs are different...
OT: But does anyone know where to get a y8 tranny or equivilant online/shipped for cheap?
Old Mar 24, 2004 | 11:08 AM
z6's Avatar
z6
what is aluminum in the z6 that isnt in the y8?
Old Mar 24, 2004 | 11:11 AM
allmotaeg6's Avatar
Default Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">what is aluminum in the z6 that isnt in the y8?</TD></TR></TABLE>
the shift fork in the z6 is aluminum and in the y8 its steel it will bend before it breaks
Old Mar 24, 2004 | 11:32 AM
5thGenCivicKid's Avatar
Default Re: (pr0ject Eg6)
yea the y8 is deff better
Old Mar 24, 2004 | 12:00 PM
skip.two's Avatar
Default Re: (5thGenCivicKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thGenCivicKid &raquo;</TD></TR><TR><TD CLASS="quote">yea the y8 is deff better</TD></TR></TABLE>
only in terms of their shift forks. otherwise, they are the same.
Old Mar 24, 2004 | 01:30 PM
lawlerlaw's Avatar
Default Re:
well i have 2 friends with y8 trannies and they both have 3rd gear grinds, and my z6 tranny just recently got a 3rd gear grind im not sure which tranny to get now..
Old Mar 24, 2004 | 01:36 PM
Ronnie Curtis's Avatar
Default Re: Re: (lawlerlaw)
i've heard that on 96+ , the input shaft seems to have problems more often then they should..but i don't have any personal experience with that issue though...
Old Mar 24, 2004 | 01:43 PM
EL Vap133's Avatar
Default Re: Re: (Ronnie Curtis)
I have had main input shaft bearing problems with 2 97 trannies.
Old Mar 25, 2004 | 10:06 AM
Echo7847's Avatar
Default Re: Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I have had main input shaft bearing problems with 2 97 trannies. </TD></TR></TABLE> I had it myself on my z6 tranny also
Old Mar 30, 2004 | 10:50 AM
ME SO FST's Avatar
Default Re: Re: (Echo7847)
This is all great info, anyone else have anything to say about them?
Old Mar 30, 2004 | 11:53 AM
Uncle Ben's Avatar
Default Re: Re: (ME SO FST)
My friends y8 has problems with the input shaft (has about 105k on it), but he beats on it daily. My z6 on the other hand has a very slight 2nd/3rd grind (77k)and I bought it off of the 60 year old original owner! So IMO both have their good and bad points.
Old Mar 30, 2004 | 12:04 PM
elevatethis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lawlerlaw &raquo;</TD></TR><TR><TD CLASS="quote">well i have 2 friends with y8 trannies and they both have 3rd gear grinds, and my z6 tranny just recently got a 3rd gear grind im not sure which tranny to get now..</TD></TR></TABLE>
3rd gear grind @ high rpm = motor/tranny moving thus causing a grind when you try to go into 3rd
new mounts should fix that...
Old Mar 30, 2004 | 12:13 PM
heyyou82's Avatar
well, if these two trannies are the same, can you put the steel shift forks from a y8 in to a z6 tranny?
Old Mar 30, 2004 | 01:20 PM
DV98CVC's Avatar
Default Re: D16Z6 or D16Y8 Tranny (heyyou82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heyyou82 &raquo;</TD></TR><TR><TD CLASS="quote">well, if these two trannies are the same, can you put the steel shift forks from a y8 in to a z6 tranny?</TD></TR></TABLE>
um...y not just throw in the y8, much easier
Old Mar 30, 2004 | 06:28 PM
heyyou82's Avatar
Default Re: D16Z6 or D16Y8 Tranny (DV98CVC)
well, shift forks should be cheaper than buying a whole new tranny
