Just went throuygh a puddle and threw on my CEL
Old Oct 22, 2001 | 01:42 PM
2k1TypeR0610's Avatar
New User
Default Just went throuygh a puddle and threw on my CEL
I was wondering how to get the code on a '99 Si. I have the AEM CAI With a bypass valve so I'm pretty sure it isn't hydrolocked and I was able to drive 50 miles home with it. But I but I need to know how where I can gte the code being thrown.
Thanks
Old Oct 22, 2001 | 02:26 PM
maxim's Avatar
Default Re: Just went throuygh a puddle and threw on my CEL (2k1TypeR0610)
chances are the O2 sensor on your cat got wet, check that. I wouldn't worry about water getting into the engine by way of intake if it was only a puddle. How big of a puddle are we talkin' here?
Old Oct 23, 2001 | 09:52 AM
Jackson's Avatar
Default Re: Just went throuygh a puddle and threw on my CEL (maxim_force)
check the code. look under your glove box by your ecu. you should see a green rubber housing with 2 plugs in it. use the one with 2 wires and stick a paper clip in each pin to loop it. it will flash you codes.
90SiHatchy
Dec 23, 2012 04:21 PM
nixcite
May 16, 2008 09:06 AM
pinoyboiwonder
Feb 5, 2006 05:44 PM
snatch
Dec 17, 2004 11:13 AM
BigBoyJohn
Dec 26, 2003 11:35 AM
