CEL Check - 1996 Civic Hatchback DX (what code is it throwing?)(VID)
https://home.comcast.net/~effinnwackk/FEB506.MPG
heres a vid..
what code is it throwing??
is it a code 65 - Secondary oxygen sensor heater wire (black wires)
heres a vid..
Ive never had any luck fixing o2 sensors...I just replace them
http://www.sparkplugs.com get a denso first time fit unit
Re: (pinoyboiwonder)
You reset the code to see if its a dummy code. If its not just replace the o2 sensor, its alot easier then trying to fix them. Did you do anything to the o2 before your code threw?
Your friend is probably right - get under the car and stop being lazy.
If the wires look good, get a meter, disconnect the O2 from the engine harness and measure between the two black wires. Should be 15-40 ohms. Replace it if it's not.
YaBoiTHiZZ
12
03-28-2012 08:10 PM
scarface50370
12-14-2005 01:21 AM
b18_crx
10-27-2005 05:19 AM
turbotime
07-20-2003 08:11 AM
