Corner lamp problems on JDM front end
Old Mar 24, 2004 | 12:14 AM
Uneekpinoysk8er's Avatar
Default Corner lamp problems on JDM front end
well i was trying to put the USDM plug into the corner lamp of my JDM ITR headlights and it doesnt fit. Do i need the JDM plug? what could be my problem?
Old Mar 24, 2004 | 06:05 AM
eternity0114's Avatar
most people who do jdm conversions don't know, but the corner light is only a signal light. It only blinks, therefore its only a single filament bulb. The JDM plug is different, and is a bit smaller. What you can do on the US plug is just shorten those plastic pieces that locks the plug in place. That way, they will fit into the housing and lock
Old Mar 24, 2004 | 06:49 AM
JDMjames's Avatar
Default Re: Corner lamp problems on JDM front end (Uneekpinoysk8er)
I'm just running the JDM plus with the JDM bulbs in mine. I'm got some civic plugs that should fit with a little grinding of the tabs. I'm going to be using a dual filiament corner for the civic ones ao they stay on and blink.
Old Mar 24, 2004 | 07:16 AM
One Bad GeeSeeR's Avatar
? thats weird i was able to fit my usdm plugs in mine.
Carlo
Old Mar 24, 2004 | 07:24 AM
tilt.'s Avatar
Default Re: Corner lamp problems on JDM front end (One Bad GeeSeeR)
i wasnt, i used a dremel and shortened two of the little pieces on the bulb that lock, it works fine now.
Old Mar 24, 2004 | 07:56 AM
Default Re: Corner lamp problems on JDM front end (dr_jdm)
do i have to trim down all the teeth?
Old Mar 24, 2004 | 03:08 PM
tilt.'s Avatar
no, theres one thats just particularly larger than the others on the usdm vs jdm one.
Old Mar 24, 2004 | 03:16 PM
are the 94-97 plugs the same as 98-01 plugs? they are most likely the same. but thats was weird for me cuz i swear i was able to put mine in.i took them back out because i really didnt like the look of the amber since its always on. so i jsut stuck with the jdm plugs.
Carlo
Old Mar 24, 2004 | 03:25 PM
SilverDc2's Avatar
i have a bunch of left of blubs and sockets if you need them....i got the wholeclip and iddn't use everything.
hit me up you got my #
Kool Keith
Jan 9, 2006 01:54 PM
aser1z
Nov 22, 2005 10:28 PM
verseone
Sep 13, 2003 04:07 AM
