Upgrade injectors?
Old Mar 23, 2004 | 08:36 PM
sp0017's Avatar
Default Recommended Injector size
Been a long time since i last posted.
I am running I/H/E with cam gears and motec m4
A friend recommended prelude(h22) injectors and fuel pump.
Any other alternatives to recommend?
With this setup, i hope to get at least 190 + whp at the front wheels
Old Mar 23, 2004 | 08:40 PM
Hybrid ctr's Avatar
Default Re: Recommended Injector size (sp0017)
stock injectors should be sufficient
Old Mar 23, 2004 | 08:41 PM
Splat's Avatar
Collector-o-Guns and Drinker
<-- Far from expert
But I'd say stock would be fine for that setup.
Old Mar 23, 2004 | 08:43 PM
sp0017's Avatar
Default Re: Recommended Injector size (Hybrid ctr)
Sorry, what i meant was that i already pulling about 194whp at the front wheels. Would bigger injectors make any difference?
Old Mar 23, 2004 | 08:48 PM
Hybrid ctr's Avatar
Not unless you need it
What duty cycle are your injectors running at?
Old Mar 23, 2004 | 09:29 PM
baonest's Avatar
if you are pulling lots of air in, then upgrade your injectors. but I/H/E is nothing for an upgrade.
but if you got cams and such, then look into injector upgrades
Old Mar 24, 2004 | 08:43 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid ctr &raquo;</TD></TR><TR><TD CLASS="quote">
What duty cycle are your injectors running at?</TD></TR></TABLE>
You will be surprised at the duty cycle that Honda runs the stock injectors at.
Old Mar 25, 2004 | 05:49 AM
AssPenny's Avatar
Default Re: Recommended Injector size (ITR#132)
You could always go with prelude injectors which are a little bigger then the stock ITR injectors and they are plug in and play which is always nice.
EDIT: Doh, just re-read your post and saw the comment about the prelude injectors I think that is your best bet, plus they are cheap and you don't have to worry about running them at 100%. I don't believe you'll need another fuel pump as the stock ITR one should be enought for the prelude injectors.
touchmyHONDA
24
Apr 14, 2008 05:54 PM
ben222
Aug 27, 2007 11:04 PM
LILSOWEK
Oct 18, 2006 04:08 PM
bootlegtrader
10
Sep 19, 2005 05:40 AM
Vtec92Civic
Mar 11, 2004 08:17 AM
