Valve Seal help
Old Mar 23, 2004 | 08:01 PM
Witty's Avatar
Default Valve Seal help
I'm trying to replace my valve seals with the head on. How do I compress the cylinder so the valves don't fall in. I have an air tank. Do I need to buy an attachment that screws into the cylinder where the spark plug goes or is there an easier way?
Old Mar 23, 2004 | 08:08 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: Valve Seal help (Witty)
If you have a compression tester, the other half should fit into your air compressor hose. This is the most awesome tool for removing springs and retainers.
http://buy1.snapon.com/catalog...talog
Old Mar 23, 2004 | 09:14 PM
Witty's Avatar
I do but the other end doesn't fit on my air hose.
Old Mar 23, 2004 | 09:50 PM
the DR.'s Avatar
You need the appropriate air fitting (don't know the size off the top of my head) but I made an adapter that works perfect with my compression tester hose.
Old Mar 26, 2004 | 10:48 AM
Witty's Avatar
Default Re: Valve Seal help (the DR.)
Figured it out.
Modified by Witty at 6:56 PM 3/27/2004
dfoxengr
Oct 6, 2008 06:39 AM
averyvm
Apr 7, 2008 06:57 PM
averyvm
Oct 23, 2006 05:35 PM
Witty
Mar 27, 2004 11:02 AM
dtyst
Mar 23, 2004 11:11 AM
