Two Injectors in Series?
I was wondering if I add a low impedance injector in series with my stock injector and use a resistor that is 2 ohms lower (low impd. injector) than the stock resistor would this injector work just like one wired in series with the stock resistor but with out the stock injector?
It wouldbe for a nitrous application with a 440 dsm injector wired up with a jumper switch in parralel to the added injector to disable it when not on the bottle.
Ahh yes I do have a dry system.
My question is would hte low ohm injector work like a regular low ohm injector wired into a normal resistor box setup?
why not hook the 5th inj. to fuel, and ground, then for the power us the nitrous switch, when you push the nitro button, it sprays extra fuel?
PS i dont get your diagram, wheres power coming from and why do you have 2 resistors in there.
bangin'gearz
May 2, 2017 05:09 PM
