Help me figure out the problem, with my suspension
Old Mar 23, 2004 | 06:12 PM
AcCO12D95's Avatar
Default Help me figure out the problem, with my suspension
At high speeds around 70-75mph, my steering wheel shakes.
I've tried the following below to correct the problem:
- Got my wheels balanced, 1 week ago, doesn't shake as much as before after this, but still shakes a good amount.
- I've recently got my car aligned and my right caster corrected, due to my car pulling to the right really bad, now that horrible pulling has gone away. West End Alignment, is where I took my car in and he had did a frame push, on the right side of my car, has nothing to do with hacking/cutting of any sort.
- I've gone under the right side and made sure everything was tight or if anything was missing/torn, I cannot find anything!?
<U>Forgot to mention here is my suspension setup:</U>
KYB AGX + Ground Control Coilovers
Energy Suspension Radius Rod Bushing Replaced
Progress Camber Kit, replaces A-Arm link.
Neuspeed Strut Tower Bar
Someone help me, restore my steering so that it is stable at high speeds, my mind had been boggled on this....
Thanks!
Old Mar 23, 2004 | 06:44 PM
blondeaccord's Avatar
Default Re: Help me figure out the problem, with my suspension (AcCO12D95)
What year car is it? It might be that your car just shakes at those speeds...could be motor mounts...might also be rotors ... hmm..do you have anymore info?
Old Mar 23, 2004 | 06:58 PM
AcCO12D95's Avatar
Default Re: Help me figure out the problem, with my suspension (blondeaccord)
I have a 95.
I replaced, my front motor mount this past weekend, with the Prothane Inserts. My front mount was completely torn.
My rotors, were replaced less than 1 year ago. I got the powerstop slotted rotors.
This just came to my mind: I replaced my axles, about 1 1/2 ago, with those lifetime warranty autozone ones, but they are not ripped or torn yet. Could this cause the problem? Just a thought.
Old Mar 23, 2004 | 08:14 PM
91according's Avatar
wheel bearings but i doubt it it sounds kinda wierd how is the tread on the tires are the lugs tight
rodondoaccord
Nov 21, 2015 06:31 AM
lwmmuas
Jan 31, 2010 04:00 PM
CRXed
Suspension & Brakes
Jul 9, 2007 02:43 PM
95srv
Apr 23, 2004 07:32 AM
glagola1
Jun 13, 2003 05:52 AM
