WTF is goin on here!!!!????
Old Mar 23, 2004 | 04:46 PM
Ryan C's Avatar
Default WTF is goin on here!!!!????
I just slapped my fresh head on my motor and i am trying to put on the timing belt.
I got the 2 cam pulleys exactly at TDC with notches dead on.
I also got the not on the crank lined up with the notch on the oil pump...
then i put the timing belt cover on and it lines up fine with the crank...
then i put the crank pulley on and THE MOTHER ****** IS OF BUY A DEGREE!!!
has any dealt with this before?
the only thing i can think of is that it might be because of the N1 crank pulley, but thats OEM so i doubt it
Old Mar 23, 2004 | 05:39 PM
Ryan C's Avatar
Default Re: WTF is goin on here!!!!???? (Ryan C)
help!!!!
Old Mar 23, 2004 | 08:35 PM
Ryan C's Avatar
SOMEONE!!!
Old Mar 24, 2004 | 05:23 AM
Ryan C's Avatar
Old Mar 24, 2004 | 05:59 AM
blah13's Avatar
What I would do is put the belt on, make sure its all lined up, then go ahead and tighten the tensioner down. Then put on the crank pulley, just sounds like your slightly moving the crank when you put the pulley on. In seriousness, you can have the timing marks way off when you put the pulley on, then just loosen the tensioner and adjust the belt/gears as need be.
Old Mar 24, 2004 | 06:15 AM
mmuller's Avatar
Mad Scientist
Default Re: WTF is goin on here!!!!???? (blah13)
It happens; is hard to put the sproket mark right on with the oil pump, just line up the crank with the crank pulley and then take it off to tension it.
Old Mar 24, 2004 | 06:26 AM
Ryan C's Avatar
Default Re: WTF is goin on here!!!!???? (mmuller)
what i'm trying to say is that the timing marks dont corespond with each other.
I'm positive nothing moved whil i was putting on the pulley and the marks were off.
Mind you, i did the ghetto find TDC yourself methond with a screw driver and it DID agree with the crank/oil pump marks. just didnt seem to line up pulley to cover
But nevertheless i'm glad to be getting some feedback finally
Old Mar 24, 2004 | 06:33 AM
mmuller's Avatar
Mad Scientist
I was saying because sometimes when i put everything at tdc, all the marks line up, but when i put the pulley on the mark would be off by a little.
If its a little you should be ok
Old Mar 24, 2004 | 06:34 AM
Ryan C's Avatar
oh, that is exactly what is happening.
I've never seen this before...will i be okay to time it??
Old Mar 24, 2004 | 06:44 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">oh, that is exactly what is happening.
I've never seen this before...will i be okay to time it??</TD></TR></TABLE>
It ''should'' be ok, i did it with mine and it was fine.I couldnt seem to get to line up perfectly, but its good
Old Mar 24, 2004 | 12:51 PM
Ryan C's Avatar
did you ever try to time the car?
Old Mar 24, 2004 | 06:16 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">did you ever try to time the car?</TD></TR></TABLE>
yes and it was fine
Old Mar 24, 2004 | 07:22 PM
Ryan C's Avatar
http://www.geocities.com/suparye/gears.html
yeah, i'm gay i dunno how to post pics, try this link
Modified by Ryan C at 11:47 PM 3/24/2004
Old Mar 24, 2004 | 07:26 PM
N2O's Avatar
N2O
Did you have the head milled at all?
Old Mar 24, 2004 | 07:47 PM
Ryan C's Avatar
Default Re: WTF is goin on here!!!!???? (N2O)
i didnt mill it, and i doubt the previous owner did
Old Mar 24, 2004 | 07:56 PM
Ryan C's Avatar
are the pics workin?
Old Mar 24, 2004 | 10:42 PM
mmuller's Avatar
Mad Scientist
yeah, think thats a little too much off.
Try again, thats like a tooth or is it the pic?
Old Mar 25, 2004 | 04:56 AM
Sliced Beard's Avatar
i bet if you spin the crank with the belt on counter clockwise a little bit the two marks on teh cam sprockets will line right up
seems to me that your crank pully may have the timing marks on the wrong spot thats all.
Old Mar 25, 2004 | 06:30 AM
Ryan C's Avatar
Default Re: WTF is goin on here!!!!???? (dirtyd463)
oh man, this ***** killin me
suje
14
Feb 22, 2012 04:19 PM
Randysi
12
Oct 20, 2011 03:00 AM
dfabulous
10
Dec 9, 2007 11:00 PM
Jorsher
Oct 11, 2004 07:40 PM
Ryan C
75
Apr 21, 2004 06:50 AM
