Trying to start a new project soon(building b18c type R)
What/where should i start...
What do I need parts wise to start this project out, and what should i go w/...
im plannin on turbo'ing this car eventually...
I have around 5k-6k to put into the motor itself w/o turbo... me and my dad are building it, he knows a lot about the engines and whatnot, im just in the learning phase. Just trying to know what I should be looking for, and where are reliable sites to get the stuff??
plannin on puttin the engine into a 88 CRX.
I been searchin as well and tryin to learn on my own, thought this would maybe be a bit more helpful.
Thanx guys
Thanx guys
The Type-R is a great engine, but unless you have a great hookup on the motor they're pricey (to start out with). So here's the advice portion of my reply (see below).
First off, buy a cheap B16a (SIRI/SIRII) or B18c (GSR) and get it sleeved (GE/RS Machine and Benson) are the way to go.
While the motor is out being sleeved, send the head to get ported and built right (valves/springs/retainers) (Portflow and Headgames are top notch). Ask HEAD on (H-T) for advice, all he does is heads and knows his ****.
Depending on your HP/TQ desires, pistons and rods could be in the mix as well. Pauter/Saenz or Eagle are all quality and worth a look.
Motor wise: Replace all gaskets bearings and such and you'll be good (OEM is good).
Links
http://www.goldeneaglemfg.com
http://www.rsmachines.com
http://www.portflow.com
http://www.eaglerod.com
http://www.pauter.com
Hope that helps some
Links
thanx, do u have any idea the cost of havin the block sleeved?
and how much the labor on the head will be around??
not a def price, just an estimate on what these prices ussually go for.
thanx for the help
thanx for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88CRXdude »</TD></TR><TR><TD CLASS="quote">thanx, do u have any idea the cost of havin the block sleeved?
thanx for the help
For the block (Benson) talk to Earl here on H-T, https://honda-tech.com/zerothread?id=692320 click that and take a look
As for the head it all depends on what your hoping to acheive, you know?
As for the "famed" search button IT IS A PEICE OF ****
If you need any more help feel free to Pm me
thanx for the help
</TD></TR></TABLE>For the block (Benson) talk to Earl here on H-T, https://honda-tech.com/zerothread?id=692320 click that and take a look
Hondaboy20
Jun 15, 2005 04:45 PM
