shifting auto tranny?
Old Mar 23, 2004 | 03:36 PM
JMD's Avatar
JMD
Default shifting auto tranny?
Someone told me theres a way to shift an auto tranny like a manuel. is it true? like shift through 1-2-d3-d4. if it's true can you redline each gear or will it eventually shift for you?
Old Mar 23, 2004 | 04:25 PM
-iLLuZioN-B18C1's Avatar
Default Re: shifting auto tranny? (JMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMD &raquo;</TD></TR><TR><TD CLASS="quote">Someone told me theres a way to shift an auto tranny like a manuel. is it true? like shift through 1-2-d3-d4. if it's true can you redline each gear or will it eventually shift for you?</TD></TR></TABLE>
dont do it. leads to slipping tranny. my friend does that to his supra at and his tranny is toasst.
Old Mar 23, 2004 | 04:28 PM
.M.'s Avatar
.M.
Default Re: shifting auto tranny? (-iLLuZioN-B18C1)
chip ecu .. like a mugen ecu or jdm ecu something..
Old Mar 23, 2004 | 05:30 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
It is just an easy to way to destroy a tranny.
Old Mar 23, 2004 | 05:32 PM
Undercover_Skank's Avatar
just ***** up the tranny faster....there no point in shifting in an automatic. thats why they call it automatic, it shifts by itself
Old Mar 23, 2004 | 06:04 PM
bub838's Avatar
just let the damn thing do what it was made to do.
Old Mar 23, 2004 | 06:08 PM
timmy8151's Avatar
Default Re: shifting auto tranny? (BaLcH1o4sHeEzY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaLcH1o4sHeEzY &raquo;</TD></TR><TR><TD CLASS="quote">chip ecu .. like a mugen ecu or jdm ecu something.. </TD></TR></TABLE>
How's a chip going to help with manually shifting an auto?? Also, most of these "mugen" chips are garbage and not worth it.
mintegra97's Avatar
Default Re: (bub838)
before i did my manual swap, i fucked up my auto tranny. i would shift all of time with it. i also do neutral drops all of the time. It really fucked up my tranny though and i'm glad that i did it, it was fun.
Old Mar 23, 2004 | 07:05 PM
bub838's Avatar
right before i do my swap. im gonna neutral bomb till there's no tommorw.
i mean, who wants an auto tranny anways
Old Mar 23, 2004 | 07:40 PM
totalchaos's Avatar
make sure you got all the parts for ur swap b4 u blow ur slush box. that's the only thing i regret about blowing my auto tranny And even if your in 2nd, s3, or s4 it will rev higher but it will eventually shift into another gear, mine did shift at redline though if i stayed in 2nd too long or s3 or s4 and eventually in to drive. I actually punched a small hole in the tranny b4 it finally died. If u really want it to go out just manually shift every chance you get and race, and pull a bunch of e-brakes and neutral drops and then when it's been slipping for a while rear end some one, that's what finally ended it for me
Old Mar 23, 2004 | 08:52 PM
zilverz's Avatar
Every single one of these guys that posted did not know what they were talking about.
FOR THE 10000000000000000000000000 time
*Note* I have manually down shifted my auto for 3 years+
Manually shifting your gears on an Auto tranny WILL WILL WILL NOT Destroy or Speed the death of your Auto tranny. It does ABSOLUTELY nothing PHYSICALLY different to the tranny than you flooring it and letting the ECU downshift for you
Neutral Drops and FLOORING the car period is what speeds the death of Auto trannies
There is no sense in Upshifting any of your gears. The Auto ECU will Rev to your Rev limiter when the car is floored and shift. No benefit from upshifting. 3rd Gear the auto will shift into 4th gear premature. So if your doing a 1/4 mile run leave the shifter in 3rd gear
Benefit lies in Manually Downshifting your gears. When you manually down shift and floor it .. it does it IMMEDIATELY. When you Floor the car and the ECU downshift fors you.. it takes a slight second longer.
Downshift and Floor it at these intervials for the biggest torque jump on the auto tranny
4th @ 2500 RPM -&gt; 2nd gear
2nd @ 3000 RPM -&gt; 1st gear
Of course you will need to upshift before it hits fuel cut off
Old Mar 23, 2004 | 08:53 PM
zilverz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bub838 &raquo;</TD></TR><TR><TD CLASS="quote">right before i do my swap. im gonna neutral bomb till there's no tommorw.
i mean, who wants an auto tranny anways</TD></TR></TABLE>
LOL yes i want to blow mine up with nitrous before i convert .. see just how much it CAN take
Old Mar 23, 2004 | 08:58 PM
bub838's Avatar
hey...all in the name of science right? someones gotta answet aht question "how much nitrous can my poor auto take?"
MKCSRet
Apr 26, 2014 06:32 PM
Katpwr
Jul 11, 2013 03:35 AM
MrPl2e5t0n
Nov 9, 2007 09:33 PM
greenf1
Aug 27, 2004 08:30 PM
