Switched tires...now my car raised a little
Old Mar 23, 2004 | 09:19 AM
grlstockb18c1's Avatar
Default Switched tires...now my car raised a little
Ok boys heres the situation:
On saturday I switched my gsr fat fives w/khumo tires for the gsr blades with some factory fat michilen tires. My cars lowered and after I switched them, the height of the car raised a little. Now is it going to stay that way? Or is it just going to settle in? Thanks
Old Mar 23, 2004 | 09:24 AM
bboynekro's Avatar
tires are either skinner or fatter so it appears to be higher I seriously doubt you changing out 15s for 15s makes your car any lower or higher, its all about how wide those tires are are
Old Mar 23, 2004 | 09:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Switched tires...now my car raised a little (girlieb18c1)
what size was the kumho tires?
Old Mar 23, 2004 | 10:15 AM
Default Re: Switched tires...now my car raised a little (PatrickGSR94)
lol...I cant find the number. But I do know that its 195/55/15 and they are Kumho Ecstas 711??Those were the ones on the old rims( I couldnt find the same ones) But I bought some 195/55VR/15 Kumho Ecsta Supra 712's b/c I cant stand those fat michilen ones!!!
Old Mar 23, 2004 | 10:19 AM
purplegsr's Avatar
well, the stock michelin ones are also 195/55r15, so if you are running that size your car shouldn't be any lower or higher, unless you have too much air or something. I think it's more likely that it just looks high because it hasn't settled back down after being on a lift or a jack, wait a day and see how it does. Now, if your new tires are 205/55 or something, then that's why you're higher.
Old Mar 23, 2004 | 10:27 AM
Default Re: Switched tires...now my car raised a little (purplegsr)
Yah the tire sizes are the same. Maybe they have too much air, cause this guy put air in all the tires after we put em on. The reason why I say that its higher is b/c I dont scrape or bottom out anymore. I'm not saying that I liked it, I just love being low.
Old Mar 23, 2004 | 11:07 AM
IntEGNYC's Avatar
ok girl.
if the rims and the tire sizes are identical, it must be your imagination. lay off the smack.
If your car is lowered and the springs arent loaded, (as most folks dont do) then they should settle lower to a normalized height after you jump in the car and drive over a few bumps.
Old Mar 23, 2004 | 11:11 AM
TEXN3's Avatar
Default Re: Switched tires...now my car raised a little (IntEGNYC)
there is the possibility that the michelins have more tread on them. remember, as tires get more miles and wear on them, the height of the tread goes down. its only noticeable up close.
also, michelins have a "sqaured-off" corner for better wet traction and wear. tires such as the kumhos are usually rounded at the corners for better contact when the tire is in a turn. this is why michelins kinda suck in high speed cornering, the shoulder of the tire isn't making as much contact as the kumho might be.
Old Mar 23, 2004 | 11:24 AM
Default Re: Switched tires...now my car raised a little (texnteg)
Thanks for the replys guys, I appriciate it. Yah the guy at the tire place was saying what you said about the whole shape of the michilen being squared. I just cant wait till I get my kumhos back on later on this week
Johnoolo
Dec 1, 2013 09:13 AM
p nut
Feb 18, 2010 02:10 PM
pinkspider
Sep 15, 2009 07:40 PM
Rob.
Dec 27, 2008 01:17 PM
Vantage
Apr 1, 2007 02:02 PM
