just reseted my ecu... weird idle now. help
Old Mar 23, 2004 | 06:17 AM
..::91TEG-G2::..'s Avatar
Default just reseted my ecu... weird idle now. help
well i was reading that *reset ecu* forum and i read the instructions on how to do it, which was:
run car until it reaches normal temp, park car, pull back up fuse and ecu fuse under the hood, let car sit for 10-15 mins (which i did), put fuses back in, turn on car and let it run for 10-15 mins w/o touching the gas or any electronics do draw power.. then drive around and see if u feel a difference or not(i have i/e)
be4 my car used to idle at 500rpms.. lets say when i drive, then put it in neutural, it would stay at 500, smooth idle.. now its up to 1250 exactly.. but when i drive it around for a little bit longer, it goes back down to 400-500 rpms.. and i did the resetting ecu twice because it was flipping out on the high idle..
anyone know why it did this high idle now and didnt do it be4 the ecu reset?
Old Mar 23, 2004 | 06:22 AM
dip-set's Avatar
Default Re: just reseted my ecu... weird idle now. help (..::91TEG-G2::..)
maybe u forgot to turn the car backk off then take it out for a drive...by turning the car off first it saves what u reset...
Old Mar 23, 2004 | 06:26 AM
Default Re: just reseted my ecu... weird idle now. help (b18b-se)
so drive car, park it, take out fuses, let sit, put fuses back in, start car w/ no gas pressed, turn car off, turn back on, then drive around?
but see heres the weird thing... my car when i drove it around the first time be4 i did the resetting, was idleing at 500 rpms.. then i let the car sit for 10 mins w/ the fuses out, put them back in, turn the car on, now it idles at 1250 or so.. so if the car was still very warm, why did the rpms change so much?
Old Mar 23, 2004 | 09:48 AM
bump
Old Mar 23, 2004 | 11:06 AM
zilverz's Avatar
yes, you have to shut the car off after the calibration period for the ECU to know it ended ... otherwise your slamming the gas while its still trying to calibrate..
Old Mar 23, 2004 | 11:46 AM
Default Re: just reseted my ecu... weird idle now. help (zilverz)
k, ill do it again today..
Old Mar 23, 2004 | 03:56 PM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zilverz &raquo;</TD></TR><TR><TD CLASS="quote">yes, you have to shut the car off after the calibration period for the ECU to know it ended ... otherwise your slamming the gas while its still trying to calibrate..
Old Mar 31, 2004 | 06:22 AM
boricuacvc's Avatar
Default Re: just reseted my ecu... weird idle now. help (xteg01)
i have about the same problem. the car is idleing very high. high enuf that if i put the car in gear, it will drive at least 20 mph without even touching the gas. if i reset the ecu, would it go back to normal? what could be the problem? how do i reset the ecu? what is a cel? where can i find it and know what it means? i need help!
hondaZvic
Jun 29, 2010 02:20 PM
danslerugueux
18
May 15, 2004 01:12 PM
civicracer1993
Nov 11, 2003 07:08 PM
arren123
Mar 27, 2003 11:15 AM
