how high can a gsr rev to?
Old Mar 23, 2004 | 06:16 AM
MrBui's Avatar
Default how high can a gsr rev to?
just got a full REV valve train and im wondering how much higher can i go on a gsr cam? anybody know?
Old Mar 23, 2004 | 06:33 AM
advanracing62's Avatar
Default Re: how high can a gsr rev to? (n20need4vtec)
stock- the cams are pretty much maxed out at that point- time to get some real cams in there.... especially if you want more power at a higher RPM
Old Mar 23, 2004 | 06:38 AM
MrBui's Avatar
Default Re: how high can a gsr rev to? (advanracing62)
well its gonna be boosted probably will stick with stock rev limit anyways
Old Mar 23, 2004 | 07:43 AM
Undercover_Skank's Avatar
my buddy takes his stock gsr with ctr cams to 9500 rpm turbo.....easily
Old Mar 23, 2004 | 07:47 AM
95 integra's Avatar
Default Re: how high can a gsr rev to? (Vietvicious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vietvicious &raquo;</TD></TR><TR><TD CLASS="quote">my buddy takes his stock gsr with ctr cams to 9500 rpm turbo.....easily</TD></TR></TABLE>
Is that turbo'd and ctr cammed? Either way, I wouldnt take it over 9200 personally and that would only be with stage 2+ cams, stage 1s are probably good to around the 8800 mark. Turbo'd cars usually dont make good enough power(especially with ctr cams) to rev past 8500 or so...unless you put aftermarket cams in(read...turbo cams).
Old Mar 23, 2004 | 05:30 PM
Default Re: how high can a gsr rev to? (95 integra)
i beleive its ctr cams..it might be itr. im not sure. all i know is that he takes that thing to 9500 rpm
Old Mar 23, 2004 | 05:40 PM
VsR785's Avatar
that thing better have a nice valvetrain to be able to do that...thats crazy, but ive never heard of that **** on ctr ****..i dont know.
Old Mar 23, 2004 | 05:47 PM
Kendall's Avatar
There is a lot of information about this in the all motor forum. Honestly, the stock gsr cams are already falling out of their powerband by 8100 rpms, in fact the CTR/ITR cams don't even peak that high, but they don't really start to fall out until their redline. Revving any higher is just unnecessary wear on the engine. If you plan to take the gsr over about 8400 rpms, then I highly suggest upgrading to a different valvetrain. And as far as aftermarket cams and valvetrain are concerned, each aftermarket cam will be different so i suggest you find dyno charts for any that you are considering for your engine. Also use the recommended valvetrain for any cams you might use.
Old Mar 24, 2004 | 07:36 AM
MrBui's Avatar
Default Re: (Kendall)
thanks for the info...just wanted to know what it could handle..im sticking with the stock redline
Old Mar 24, 2004 | 08:06 AM
neo1z's Avatar
Default Re: (n20need4vtec)
There is no reason to take CTR's that high...he is just asking to bend some ****.
What kind of turbo setup will you run? You'll be ABLE to rev plenty high, whether or not you want to will be up to you and the dyno.
Old Mar 24, 2004 | 08:38 AM
FastSS's Avatar
Default Re: (neo1z)
98- CTR intake cams have 3 degrees more durration, 98+ CTR and ITR are the same...
Im building an "NA Monster" and I only plan on reving it to a maximum of 9500 with toda valvetrain, Toda Cams and some other goodness... the main thing is that a stock bottom end is not meant to rev that high
Old Mar 24, 2004 | 08:43 AM
jdmorphanage.ek9's Avatar
taking something to 9500 and making power to 9500 are 2 different things. no way in hell a CTR cam makes power till 9500, you can rev all u want, but its useless, as for your question.. gs-r cams make good power up too 7500-8000 no need for anything more.
Old Mar 24, 2004 | 10:53 AM
MrBui's Avatar
Default Re: (neo1z)
well it basically is gonna be all top end power...84mm 9:1 gsr,sc61,lovefab mani and the victor x intake
Old Mar 24, 2004 | 02:51 PM
Default Re: (chuckdizzL)
i didnt say anything about how much power it makes. i just said how high it revs. yeah i know that the power band cuts off way before that tho....
xcon0570
Jan 28, 2007 05:57 AM
94IntegraLs04
May 10, 2006 08:38 PM
Easyslider01
May 6, 2005 10:11 AM
IgniteTeg
May 19, 2002 12:23 AM
Acura97GSR
Jul 12, 2001 11:23 PM
