Is CTR valvetrain on GSR head ok?
Old Jan 24, 2007 | 12:06 PM
xcon0570's Avatar
Default Is CTR valvetrain on GSR head ok?
Is CTR valvetrain(springs & retainers only) on a stock GSR head ok? Gsr cams and valves for now and will try to get itr cams later. Will there be complications or problems? Until how much can I rev up if this will work? LMK. Thnx.
Old Jan 24, 2007 | 05:22 PM
mmuller's Avatar
Mad Scientist
Default Re: Is CTR valvetrain on GSR head ok? (xcon0570)
bolt in affair. rev limit will depend on cams, but you dont need to rev any higher than stock itr specs; your not making any power up there.
i would not use stock valvetrain on anything but stock cams
Old Jan 25, 2007 | 12:09 PM
xcon0570's Avatar
Default Re: Is CTR valvetrain on GSR head ok? (mmuller)
How much can I rev on stock gsr cam?
Old Jan 28, 2007 | 05:57 AM
EnjoyTheRideDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcon0570 &raquo;</TD></TR><TR><TD CLASS="quote">How much can I rev on stock gsr cam? </TD></TR></TABLE>
How high you can rev is not solely dependant on a camshaft. Your valvetrain provides you with the ability to handle a specific power load, ECU electronically limits your ability to rev past a programmed point, and so on. So you can rev up to 10K with a GSR cam, as long as your ecu and valvetrain allow you to, but its not like you'll be producing power at that point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcon0570 &raquo;</TD></TR><TR><TD CLASS="quote">Is CTR valvetrain(springs & retainers only) on a stock GSR head ok? Gsr cams and valves for now and will try to get itr cams later. Will there be complications or problems? Until how much can I rev up if this will work? LMK. Thnx.</TD></TR></TABLE>
Yeah, it will work. No complications what so ever...no horsepower gain as well. On a GSR cam, no point in setting your rev limit anywhere past the stock point because you will yield no benefits what so ever.
zigg_1311
Aug 9, 2007 01:23 PM
94IntegraLs04
May 10, 2006 08:38 PM
MrBui
Mar 24, 2004 02:51 PM
IgniteTeg
May 19, 2002 12:23 AM
Acura97GSR
Jul 12, 2001 11:23 PM
