problem fitting aftermarket headers in crx
well like the title says i have a problem putting in aftermarket headers, bc i have a gsr engine swapped into my crx....so would the only thing to do is get an si radiator or is there anyway i can put them on with the gsr radiator still in place
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson »</TD></TR><TR><TD CLASS="quote">you're lucky the crossmember isn't in the way like mine is
yeah i have the same prob so i couldnt use a header right now...will an aftermarket xmember leave enough room for a 4-1 header-anybody know?
</TD></TR></TABLE>yeah i have the same prob so i couldnt use a header right now...will an aftermarket xmember leave enough room for a 4-1 header-anybody know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">you have to get a header designed for a gsr motor because the block is taller, b16 header will not fit.</TD></TR></TABLE>
a b16 will fit-however it is very close to the oil pan and u have to cut off the bracket (where a bolt goes) thats on the b16 header to make it fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krissigsrcrx »</TD></TR><TR><TD CLASS="quote">
yeah i have the same prob so i couldnt use a header right now...will an aftermarket xmember leave enough room for a 4-1 header-anybody know?</TD></TR></TABLE>
from what I hear bars like from Jim Fab really give you alot more room. have'nt sen in person how much though. Maybe someone that has one can tell us?
user 996328629
11
Nov 19, 2004 07:56 PM
