can machine shops balance a crank pulley?
I've had a crank pulley on my gsr for a while now, but im just thinking. It is chipped slightly on the outer diameter, which probably would affec the PS belts, but since im not running PS, im okae. Well anyways, it probably does throw off the blanace slightly. If I were to take it to a machine shop, would they be able to balance it perfectly? maybe by taking off slight material from the other end? Is it a service that machine shops do? thanks
Everything will have some effect on the balance. Some machine shops will have the capabilities to balance it, and some won't. If you are running without A/C as well, just invest in a CTR N1 pulley.
i was refering to why aren't u running an aftermarket one..
did you get your problem fixed yet? i'm pretty sure if you bring it somewhere that does machining they could balance it.
