Hondata question Using romeditor 3.5.5 & still getting O2a cel (running openloop)
Old Mar 22, 2004 | 07:35 PM
turbolsintegra26's Avatar
Default Hondata question Using romeditor 3.5.5 & still getting O2a cel (running openloop)
OK, I went to the hondata seminar and I asked about this and I found out I had not actually updated my ROM's to 3.5.5, They said that should fix the problem, but I have done that now and burned a new chip and even run the updated ROM off my romulator. I still get the CEL O2a when I deccelerate. Is anyone else still getting this code, and any suggestions why? OH, and one other issue, this maybe related, but when I plug my wide band into the factory harness my car goes 1 to 2 points richer and I'm still running open loop. I'm using the LM-1 wideband if that helps. Thanks Justin
Old Mar 22, 2004 | 08:54 PM
boostismycrack's Avatar
E-thug
Default Re: Hondata question Using romeditor 3.5.5 & still getting O2a cel (Turbointegra22)
my **** does the same
Old Mar 23, 2004 | 06:34 PM
Has anyone talked to hondata about this problem and had any type of response?
Old Mar 24, 2004 | 09:46 AM
Hondata's Avatar
After speaking with the software developer, the bug may still exist. It is not a real problem, and nothing you should worry about. We will attempt to correct this in a later release of Romeditor, but for now we are working hard on the K-Series releases and will get back to the older systems as time permits.
Old Mar 24, 2004 | 10:41 AM
turbosi03's Avatar
same thing happends to me... I was assuming my o2 sensor was fouled up from driving untuned and rich for a while... it's just annoying to see the eng light go on, but I have had much worse problems.
Old Mar 24, 2004 | 11:55 AM
Default Re: Hondata question Using romeditor 3.5.5 & still getting O2a cel (Hondata)
Thanks for the info, If its not a threat then its no big deal, just annoying, try to fix it when you get a chance. By the way your K-series work is sick, you guys are genius when it comes to cracking honda's computers, keep up the good work.
Zaraki
Engine Management and Tuning
Oct 28, 2013 07:17 PM
Thateguhate
Apr 27, 2007 03:01 PM
THEUSED
Apr 1, 2006 04:08 PM
SwappedTURBOegg
Aug 27, 2005 04:34 PM
danny98r
Jan 16, 2005 07:51 AM
