Abnormal surging
Old Mar 22, 2004 | 05:53 PM
Liquidgsr's Avatar
Default Abnormal surging
When i first start my car it goes up to 2500rpm. Then after warming up a little it surges between 1-2000rpm. Then finally when its halfway in the middle of of cold and hot it sits just below 1000rpm. It didn't do this before but maybe like 2 or so weeks ago started this weird surging. Any ideas? Any solutions?
Old Mar 22, 2004 | 07:17 PM
ingrate's Avatar
25 Year Member
Default Re: Abnormal surging (Liquidgsr)
First thing is check the coolant level in the radiator and overflow bottle. Bubbles in the system will cause a surging idle.
Old Mar 23, 2004 | 09:10 AM
Liquidgsr's Avatar
yeah i checked all that. Oil is fine. Coolant is fine. All the liquids are fine. I don't understand why its doing this now. Any other ideas?
Old Mar 23, 2004 | 09:16 AM
WreckedTeggie's Avatar
My b16 has always done that when its cold... Maybe it's just the weather?
Old Mar 23, 2004 | 09:39 AM
Liquidgsr's Avatar
Default Re: Abnormal surging (WreckedTeggie)
no it does it even when im at a stop light.
Old Mar 23, 2004 | 10:31 AM
[HrZn]4life's Avatar
vacuum leak?
Old Mar 23, 2004 | 10:42 AM
Liquidgsr's Avatar
Default Re: Abnormal surging ([HrZn]4life)
where though. They all seem to be fine. Where would there be a vacume leak? The break booster is fine. i checked the other ones i don know. Seems weird.
Old Mar 23, 2004 | 10:48 AM
frostedp0rnflakes's Avatar
Check the i.a.c valve (idle air control). When they get sludged up, it tends to do that. Try unplugging it while it is happening, if it stops then that is your problem. I hope this helps.
Old Mar 23, 2004 | 10:53 AM
Rory Breaker's Avatar
Fast idle thermo valve.
Its under the TB, held on by 3 10mm bolts. Remove it and make sure its all the way screwed in. If it is, wrap the SOB in duct tape or something to block off flow on top and reinstall it. Ghetto fix, but it works if you dont want to replace it.
You can test it by pulling off the intake while its idling, and plugging the lower hole inside the TB with your finger. If the idle dies down and stays steady, fitv is bad.
Old Mar 23, 2004 | 11:22 AM
Liquidgsr's Avatar
Default Re: Abnormal surging (newgsrdriver)
yup that did the trick. Now how much does a new one cost?
Old Mar 23, 2004 | 11:39 AM
Liquidgsr's Avatar
is it in the back closer to the firewall with a electricle connection to it? I don't see the 3 10mm bolts on it. I see 2 screws on this though, is that it?
Old Mar 23, 2004 | 12:10 PM
Liquidgsr's Avatar
actually i don't see two screws...there are rivets on them. Do i have to take the whole throttle body off for this, because i can't find the 3 10mm you are talking about.
Old Mar 23, 2004 | 12:11 PM
Thats the IACV.
The FITV is directly under the TB. On the actual underside.
3 10mm bolts with the heads facing the ground hold it in. You can remove it from the TB, just a hose and the 3 bolts.
Old Mar 23, 2004 | 02:42 PM
Liquidgsr's Avatar
took off the throttle body, took the valve off...then put duct tape over that left hole and put it back on...its all done. Finally damn junker. Now to worry about my rear LCAs and the damn bushings. Just wish i knew a place to take the suspension to get that put on and get them to put new bushings in.
Old Apr 2, 2004 | 06:19 PM
95 integra's Avatar
i tried that, didnt help my problem...same crap though.
honcrf150
13
May 29, 2012 10:28 AM
blackEGFTW!
10
Apr 13, 2009 01:08 PM
tpatt
Apr 28, 2007 05:21 AM
calinomad
Oct 1, 2006 04:41 PM
huge230
May 12, 2006 02:00 PM
