building b16 help
Old Mar 22, 2004 | 03:48 PM
1gen crxer's Avatar
Default building b16 help
ok i want to make it a daily driver, crx si 90-91 i havent go the car yet but i want to make it a daily driver gunna turbo in the future. I hear good things about putting type r cams in the b16 with type r rocker arms and valve springs. i am gunan turbo so what would you guys suggest i am new to this and i will like any advise. I want the car to be able to beat gt's maybe pump out a little more then 200 hps at teh wheels. i know im gunan need je forged pistons with a low compression ratio for teh turbo and eagle rods. correct me if im wrong with that as i said im, new the only thing i have done is motor swap nothing with internal motor parts. the car is also gunna be a daily driver in the summer and maybe a show car in teh future
Old Mar 22, 2004 | 04:46 PM
deftones0817's Avatar
Default Re: building b16 help (1gen crxer)
you should be able to make a b16a get over 200 hp with a stock engine. I would just replace all the gaskets before i put the engine into the car. Get it tuned and you should be good. Check out the force induction forum for your turbo questions and type r cams should be good but i would get the ctr cams same thing but usually cheaper than itr cams.
DEF
Old Mar 22, 2004 | 04:58 PM
1gen crxer's Avatar
yes when i said type r cams i mean the ctr i hear more aggressive than the itr cams
jachrist
Mar 9, 2010 09:20 AM
vtec4max
Jul 23, 2007 02:56 PM
sean7001
May 11, 2007 01:19 PM
R1_Owner
12
Dec 5, 2005 10:00 AM
xxwhixx
Oct 20, 2005 08:37 PM
