List your suspension setup
Old Mar 22, 2004 | 03:25 PM
whackassfawker's Avatar
Default what kind of coilovers or susp setup are you using?
I'm in the market now as I've finished the motor and need the suspension to keep up.
Old Mar 22, 2004 | 03:31 PM
1GreyTeg's Avatar
Default Re: what kind of coilovers or susp setup are you using? (Type R #0008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R #0008 &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the market now as I've finished the motor and need the suspension to keep up.</TD></TR></TABLE>
Keep up with what?
It would help if you first Searched.
Then of course listed your goal, purpose & budget.
Old Mar 22, 2004 | 03:38 PM
Misfit's Avatar
Default Re: what kind of coilovers or susp setup are you using? (1GreyTeg)
I am not totally happy with my GC set up... I need to play around with it a bit more this weekend.
Old Mar 22, 2004 | 03:43 PM
96 Ls lnTeG's Avatar
Default Re: what kind of coilovers or susp setup are you using? (misfit)
Gc's Neuspeed/Koni's
Carbing 3pt
Carbing Rear
Srr Sway an tie bar
Skunk2 Camber Kit
Ingalls Rear
SRR Toe Kit
Gsr Strut Bar
Modified by 96 Ls lnTeG at 9:55 PM 3/22/2004
Old Mar 22, 2004 | 03:47 PM
1GreyTeg's Avatar
Default Re: what kind of coilovers or susp setup are you using? (96 Ls lnTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Ls lnTeG &raquo;</TD></TR><TR><TD CLASS="quote">Gc's Neuspeed/Koni's </TD></TR></TABLE>
Application here guys, what exactly are we all doing with these setup's?
As well, maybe list rates and if the shocks were valved or revalved or servicable, rebuildable, downtime and whatnot.
Not just
Old Mar 22, 2004 | 03:51 PM
Misfit's Avatar
ah yes..
Daily driven and the hope to some HPDE's.
450F/350R GC's
with Koni Yellows.
I am going to swap the rear to the front this weekend to see if it is something that I will like.
Old Mar 22, 2004 | 05:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Not just </TD></TR></TABLE>
Daily Driving just a hobby
Old Mar 22, 2004 | 06:03 PM
DCR's Avatar
DCR
GAB Stroke II Revolution Coilovers
Street springs: Tanabe F8K R6K
Track springs: GAB F14K R12K
Old Mar 22, 2004 | 07:54 PM
Kendall's Avatar
Ohlins Parallel Control Valve (PCV) coilover setup. 14kg/mm up front, 6kg/mm in the rear.
Bow Down.
Old Mar 22, 2004 | 08:17 PM
DCtwoR's Avatar
Tein HAs
-a little hard to find these days
Old Mar 22, 2004 | 08:48 PM
pm6825's Avatar
for an inexpensive and very potent suspension setup, this is what I recommend:
Eibach Pro-Kit
Koni Yellows (Neuspeed version w/ 5 adjustable perches)
Suspension Techniques F/R sway bars
Front and rear ITR Strut tower braces
Volk TE37 16X7
Bridgestone Potenza S03s
I run this on my GSR and it handles wonderfully.
Old Mar 22, 2004 | 11:32 PM
$pecial K's Avatar
Tein HR
Old Mar 23, 2004 | 12:09 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit &raquo;</TD></TR><TR><TD CLASS="quote">
I am going to swap the rear to the front this weekend to see if it is something that I will like. </TD></TR></TABLE>
Definatley try it out.. makes a world of difference. I went from being in the bottom of the pack in SM. To the fastest car on street tires the next event.
My setup
Koni Yellows
GC coils (350F/400R.)
Old Mar 23, 2004 | 12:17 AM
itr1244's Avatar
Default Re: what kind of coilovers or susp setup are you using? (DCtwoR)
I have Tein Hr. it's good fo me
Old Mar 23, 2004 | 12:28 AM
Bbasso's Avatar
Stock works for me
Old Mar 23, 2004 | 12:43 AM
NATURAL ASPIRATI0N's Avatar
i also have Tein HR
oem front/rear stb's
skunk2 camber kit
15x7 volk te-37's
just daily driving mainly, some autocross, i'm happy with it
Old Mar 23, 2004 | 12:53 AM
adddddaaammmm's Avatar
Default Re: (pm6825)
tein RE w/edfc. spoon lower tie, em rear bar, em c pillar bar, mugen front strut, volk ce28s 15x7 on azenis.
Old Mar 23, 2004 | 03:43 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pm6825 &raquo;</TD></TR><TR><TD CLASS="quote">Eibach Pro-Kit</TD></TR></TABLE>
What spring rate are they?
I thought its almost no different then stock.
Old Mar 23, 2004 | 04:13 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R #0008 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of coilovers or susp setup are you using?</TD></TR></TABLE>stock springs/shocks/swaybars on the front and rear.
Old Mar 23, 2004 | 06:47 AM
advanracing62's Avatar
I'm running Zeal S6 circuit rates- love em! everything else is stock suspension at this point-
Old Mar 23, 2004 | 07:22 AM
Ex-ITR5874's Avatar
Ever choose a dual spring system over a single spring suspension to find your perfect setup
Review:
https://honda-tech.com/zerothread?id=800998
Modified by ITR5874 at 6:04 PM 3/23/2004
Old Mar 23, 2004 | 07:42 AM
nEoMuGen's Avatar
Default Re: what kind of coilovers or susp setup are you using? (ITR5874)
KYB Super Special Gymkhana, Buddy Club Springs 12k Front / 8k Rear
Height = 65mm front, 80 mm rear.
Application = AutoX/HPDE
...Only autocrossed once with them, very stiff even at softest setting, very little rebounds. Fine on street with good roads.
Might have to grow some ***** and tune up the damper next time My local autox lots sucks
Old Mar 23, 2004 | 07:44 AM
austrian type-R's Avatar
Default Re: what kind of coilovers or susp setup are you using? (nEoMuGen)
JIC Magic FLT-A2 - awesome suspension
Old Mar 23, 2004 | 08:24 AM
Chris N's Avatar
Default Re: what kind of coilovers or susp setup are you using? (austrian type-R)
https://honda-tech.com/zerothread?id=603366
Here is just one of MANY threads on this.
Old Mar 23, 2004 | 11:24 AM
Big Phat R's Avatar
Spoon (Showa) N1 dampers 14K front/ 16K rear
OMP front strut bar
Mugen 26mm rear bar
6 point OMP cage
- track mostly - but still very streetable
