injector leak please help!
Old Mar 22, 2004 | 02:45 PM
jdmegciv's Avatar
Default injector leak please help!
My #2 is leaking right where it enters the IM, what is the problem?? after i shut down it continues to leak until the fuel is out of the line and then its making a whistling sound. is the inject. cracked?
btw its a b18b with a skunk IM. can anybody help me, thanks in advance.
Old Mar 22, 2004 | 04:24 PM
suspendedHatch's Avatar
Default Re: injector leak please help! (jdmegciv)
replace the o rings and be sure and coat them with oil prior to installation.
Old Mar 22, 2004 | 07:12 PM
jdmegciv's Avatar
Default Re: injector leak please help! (shaundrake)
thanks shaundrake I appreciate the help, is there any tricks to this installation?
Old Mar 22, 2004 | 08:59 PM
honda head's Avatar
what kind of injectors are you running? check if the fuel rail bolts are torqued down
Old Mar 23, 2004 | 08:53 PM
nevamind's Avatar
Go dealer and bought a set of injector seal from from them cost about $70 for all 4 injectors (this include o-ring on fuel rail, spacer, and o-ring on IM). This should solve your problem, and took about 30 min to get it done. Be sure to coated the o-ring with engine oil before install it on or else you going to crush the o-ring.
milt.6680
Aug 26, 2013 12:30 PM
ekHatchdom0
Mar 11, 2010 07:24 AM
b00sted4dr
Feb 7, 2005 10:50 AM
Cowboy
Mar 18, 2004 05:56 PM
legendboy
Aug 19, 2002 07:17 AM
