Looking for a triple gauge pod for a 4dr Integra!
Old Mar 22, 2004 | 01:12 PM
enphotography's Avatar
Default Looking for a triple gauge pod for a 4dr Integra!
Well since they dont make any for a 4dr, only 2dr, I saw a guy that made it to fit a 4dr, so does anyone know what I would need to do? are the 4dr longer then the 2dr? or whats the diffrence of a 4dr and 2dr? Where could I guy a 4dr one? Someone must know
Old Mar 22, 2004 | 01:20 PM
advanracing62's Avatar
Default Re: Looking for a triple gauge pod for a 4dr Integra! (BiGGie got a GSR)
OMG- why?
Old Mar 22, 2004 | 03:53 PM
Default Re: Looking for a triple gauge pod for a 4dr Integra! (advanracing62)
what you mean why? Maybe because I want to and need to... jesus, newbie here and already gettin clown on..
Old Mar 22, 2004 | 06:21 PM
meconfu5ed's Avatar
as far as I know they should be the same.
Old Mar 23, 2004 | 06:30 AM
Default Re: Looking for a triple gauge pod for a 4dr Integra! (meconfu5ed)
I highyly doubt that you need to have that many gauges, let alone even two, for your Integra. I know you're not a serious racer, cause you'd just make a panel for the gauges in your dash- so it must be for *BLING*.... which is ghey- Thanks though!
Old Mar 23, 2004 | 07:49 AM
meconfu5ed's Avatar
well if he boosts he might want a vac/boost gauge, oil pressure gauge, water remp gauge. panel for the gauges in the dash where? only thing I can think of is a gauge bezel surround which is kinda hard to read compared to the pillar.
Old Mar 23, 2004 | 08:53 AM
Default Re: (meconfu5ed)
actually you can fit three Autometer gauges in the panel where the radio goes- easily I might add....
Old Mar 23, 2004 | 11:26 AM
bub838's Avatar
yeah ive seen that done...advan...i like your signature too
Old Mar 23, 2004 | 11:53 AM
JDM4DR.GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGGie got a GSR &raquo;</TD></TR><TR><TD CLASS="quote">Well since they dont make any for a 4dr, only 2dr, I saw a guy that made it to fit a 4dr, so does anyone know what I would need to do? are the 4dr longer then the 2dr? or whats the diffrence of a 4dr and 2dr? Where could I guy a 4dr one? Someone must know </TD></TR></TABLE>
actually there is a difference, the four door pod is slightly larger than the 2 door and it is slightly thinner, the pod for the two door works, you just have to trim the top of the stock panel so you do not see it and you just have to be able to deal with the slight unfitment that you see through the front window, other than that it will work, (the only problem i found was placing the small plug ,to hold the pod to the panel, i actually drilled the hole used a small screw and an old bracket to hold the screw tight behind the panel)....if you have anyother questions about this just pm me or e-mail me
Old Mar 24, 2004 | 09:40 AM
Default Re: Looking for a triple gauge pod for a 4dr Integra! (JDM4DR.GSR)
Oh well thank you! I guess I will just have to mod it my self, if I get stuck I sure will contact you, you woden't happen to have any pictures of what you did? or how it looks like? I would PM you but still a trial user, and can't msg anyone. Thanx
Teglessb18
Aug 24, 2005 10:43 PM
iiilgsrlll
Jul 30, 2004 12:49 AM
