EG guys where do u mount your gagues?
Old Mar 22, 2004 | 11:53 AM
GReddy SI's Avatar
Default EG guys where do u mount your gagues?
post pics of your gauges
just trying to get some idea's where to mount my boost and a/f gauges
i dont want the side pillar pods .
< i want the sleeper mode but be able to look at the gauges clearly
Old Mar 22, 2004 | 01:00 PM
Cee_mon's Avatar
Default Re: EG guys where do u mount your gagues? (GReddy SI)
I cut out my center 2 vents and put a gauge in each.
Old Mar 22, 2004 | 01:28 PM
GReddy SI's Avatar
Default Re: EG guys where do u mount your gagues? (Cee_mon)
got pics of that?
Old Mar 22, 2004 | 01:37 PM
TABIAS's Avatar
I want to be MADE into Ice-T
A piller pod, not exactly "Sleeper" but I'm not really worried about it
Old Mar 22, 2004 | 02:16 PM
Trak_Day's Avatar
New User
I plan on building a custom motorized piece above the middle ac vents that has 3-4 gauges in it! should be pretty cool, and will hidce the gauges nicely when not in use.
Old Mar 22, 2004 | 02:33 PM
integra_gsr98's Avatar
Default Re: (DroppedGSR)
If you're looking for a spot for 3 gauges and want to relocate the radio...
Call Straight Line Specialties, ask for Nick, and tell him you are looking for a 3 gauge radio bezel for the 92-95 civics.
(701) 282-2902
Made out of aluminum, powdercoated black, red, gunmetal, blue, silver, or left unfinished.
Old Mar 22, 2004 | 02:51 PM
GReddy SI's Avatar
Default Re: (integra_gsr98)
i am only using 2 gauges , does he make those also ?
if so got any pics?
Old Mar 22, 2004 | 03:18 PM
Default Re: (GReddy SI)
I am sure he can make it with two gauges as well. His civic bezel is off @ the CNC shop getting layed out in the computer so that it can be mass produced.
Here is a picture of one of his 1g DSM vent bezels...
Old Mar 22, 2004 | 03:22 PM
slim9300's Avatar
How about something like this, they make them for an EG, I am just lazy. BTW, I have this on my Intgera, very nice!
http://cgi.ebay.com/ebaymotors...07118
Old Mar 22, 2004 | 09:02 PM
GReddy SI's Avatar
Default Re: EG guys where do u mount your gagues? (slim9300)
they dont make that for eg's
Old Mar 22, 2004 | 09:16 PM
Snail Tuning's Avatar
96 center consoule into 92 civic sedan. using a DIN slot gauge cluster.
i wanted mygauges were my cdplayer is but the cd unit wouldn't it in the place the gauges are located now, because of how the dash is attached to the floor.
warning light for oil, Vtec engaugement light, and my intercooler sprayer activation switch and working light. (spray comes on at 12psi and turns of after pressure drops below 12psi)
EGT, Oil psi, boost/vac will be moved to pillor pod, and water temp, a/f, and intake temp will be located in the lower DIN slot shown, still have to find a spot to mount my laptop, and my wide ban O2 display
Old Mar 22, 2004 | 10:37 PM
GReddy SI's Avatar
Default Re: EG guys where do u mount your gagues? (bmcc72)
nice setup
Old Mar 22, 2004 | 11:28 PM
plusONE jboy's Avatar
Bump for you, I would also like to check out to get some ideas.
Old Mar 23, 2004 | 07:38 AM
GReddy SI's Avatar
Default Re: EG guys where do u mount your gagues? (5thgenh4tch)
Old Mar 23, 2004 | 11:57 AM
GReddy SI's Avatar
bump
Old Mar 23, 2004 | 02:52 PM
GReddy SI's Avatar
anyone else got some good pics?
Old Mar 23, 2004 | 04:58 PM
TurboCoop's Avatar
i have some good pics of how I did mine but I cant post em because they arent saved on a web server or some bullshit. I still have a sorry *** dial up connection and I cant figure anything out.
Old Mar 23, 2004 | 09:11 PM
Default Re: EG guys where do u mount your gagues? (jdog1277)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdog1277 &raquo;</TD></TR><TR><TD CLASS="quote">i have some good pics of how I did mine but I cant post em because they arent saved on a web server or some bullshit. I still have a sorry *** dial up connection and I cant figure anything out.</TD></TR></TABLE>
http://www.we-todd-did-racing.com
just sign up with them.. its easy.
Old Mar 23, 2004 | 09:20 PM
yusoslo's Avatar
I'm sorry I just have to say what a horrible exexution of these guage and meter installs
I give you credit for the turbo setup, and having functional items such as an EGT and a FMIC sprayer, but not one of the guages matches up and not one panel fits right.
Take some time and make it look good.
Old Mar 23, 2004 | 09:35 PM
5STAR3's Avatar
Default Re: EG guys where do u mount your gagues? (yusoslo)
where the stock radio goes
Old Mar 23, 2004 | 09:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusoslo &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry I just have to say what a horrible exexution of these guage and meter installs
Take some time and make it look good.</TD></TR></TABLE>
first off as u can tell from the pictures that the project isn't finished yet, because none of my gauges are the same kind. ive been waiting for more than 3 weeks for my autometer ultra light gauges to arrive. apparently the seller has run into some problems.
second, everything fits perfect and lines up just right, u shoudl try holowing out a hole big enough to fit a switch into that space by the rear defroster. its a PITA, and as u can see from the picture its not even pushed in, once pushed in and one the clock block off plate is screwed down everything fits 100%. just waiting for my gauges to come in so i can finish wireing everything up.
Old Mar 24, 2004 | 03:38 AM
yusoslo's Avatar
well then that explains quite a bit. Jus dont use the radio shack push bottons on your car man.
Old Mar 24, 2004 | 05:13 AM
TRUST8383's Avatar
i didn't want my boost guage on the a-pillar, so i stuck it in the cluster...
here's my initial guage setup, but i will be putting the guages in the stock radio location because they are hard to see while driving I'm going to put the radio in the top of the console, and then put the map pocket underneath which will house the turbo timer/boost controller... i think that will be cleaner and more functional
Old Mar 24, 2004 | 06:10 AM
TurboCoop's Avatar
thanks for the link, heres what I did wth mine- in the center I took my stock plastic peice out and molded it smooth with bondo then put some real carbon fiber fabric over it and polyurethaned that so it is shiny and looks real. Where the tach is it is a 3 3/4" in dash and I just took some 1/4" hardboard and cut it to fit in the old A/C vent opening it was pretty easy, same with the switch panel. The hardest part was moving the HVAC control unit into the opening below the dash right above the cupholders. It still works though, sorry but I dont have a close up pic of it down there yet.
Old Mar 24, 2004 | 07:32 AM
rocket256's Avatar
Just get a JDM console. and go from there.
