how to test MSD products?
is there a way to see if my blaster coil is still good?
I have msd 6al and blaster2 coil....
I was having some problems with my distributor and so i replaced the OEM IGNITOR and now the car doesn't start....
I'm thinking it may be my msd box or my coil blaster, but not totally sure.
For the stock ignition coil, I checked the resistance across the Primary and Secondary connections. I'm not sure if the MSD has the same resistance specs though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 »</TD></TR><TR><TD CLASS="quote"> For the stock ignition coil, I checked the resistance across the Primary and Secondary connections. I'm not sure if the MSD has the same resistance specs though.</TD></TR></TABLE>
thank you!
now can you kinda explain what primary and 2ndary connections are???
are you referring to the termainal (power and ground)
thank you!
mrod006
Aug 1, 2004 09:48 PM
