Water pump swap....HELP!!
Ok, I've swapped heads, carbs, exhaust, seats, radiators, injectors, batteries, tires, and friggin stereos, but I've never changed a water pump on any of my Hondas in the past, and now ti's the time to learn how. I need a detailed description how to change the water pump in my Accord (Discription on sig). I can barely see it around the Alternator...and I know it's gonna be a hassle, but it has to be done, and I am not lookin forward to it
. Thanks in advance.
Justina
. Thanks in advance. Justina
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel »</TD></TR><TR><TD CLASS="quote">1. Remove timing belt
2. remove all bolts
3. take out pump.
4. Install new pump in reverse order.
Can't say much more. Sorry
fs</TD></TR></TABLE>
before you do any of that.......drain the radiator fluid
2. remove all bolts
3. take out pump.
Isn't there like somthing that I have to remove to get to the bolts?? I can barely see the water pump much less all the mounting bolts...(sorry i'm new to the whole water pump b.s.)
Justina
Justina
2. remove all bolts
3. take out pump.
#1: remove valve cover
#2: loosten timing belt covers
#3: remove water pump bolts
#4 loosten alternator
#5: take off water pump
reverse order to put on...............grrrrrrrness I did it today and it was a PAIN IN THE ***!!!!!!!!!! Left a huge chunk of knuckle on one of my brackets
~Justina~
2. remove all bolts
3. take out pump.
~Justina~
Why do you think you need a new water pump? Is it leaking? Making noise?
Everyone I know who has a Honda does the water pump when they do the timing belt, like every 90K miles. Its just too much of a pain to do it any other time unless you have to. The pump is cheap to replace at the same time.
If you didn't change it when you did your belts, it begs the question: when was the last time you changed your timing belt? If you haven't, nows the time.
I didn't do my belts....and it was leaking so I had to replace it. I could hear the bearing that went out. So now I replaced it and my car sounds normal and it isn't leaking or overheating
loveformycivic
Aug 11, 2013 12:33 PM
Powered By Garrett
Mar 5, 2005 01:20 PM
