VTEC Solonoid bad? Vtec engages, then dis-engages, the engages...
Old Mar 22, 2004 | 05:39 AM
CompressionFed's Avatar
Default VTEC Solonoid bad? Vtec engages, then dis-engages, the engages...
What's up guys. My JDM R has a vtec crossover at 6000rpms, last week at the track, I noticed a very small hesitation while at full throttle between 6k and 9k.
Last night, my vtec would sometimes engage at 6k....sometimes it would engage at 7-8k...and sometime it would engage at 6k, dis-engage, and then re-engage at 8k. It is very noticable now.
Is this just the solonoid going bad? I have no vtec controller so it may be the ecu...but I doubt that.
Thanks for your help!
Old Mar 22, 2004 | 07:47 AM
Default Re: VTEC Solonoid bad? Vtec engages, then dis-engages, the engages... (CompressionFed)
come on guys...help a brother out!!
Old Mar 22, 2004 | 08:15 AM
-Justin-'s Avatar
just a thought, but u might want to go to honda and buy a gasket kit for it and rebuild it. it might just be a dirty vtec solenoid and need new gaskets.
Old Mar 22, 2004 | 09:23 AM
ksblackcivic's Avatar
Hmm.. perhaps you should check your oil level. when the oil pressure isn't high enough, VTEC won't engage. I've had this happen when I was really low on oil. Just a thought..
Old Mar 22, 2004 | 09:43 AM
autoengineer07's Avatar
are u noticing any other problems other than the inconsistent vtec engagement? remember that several other ancilliary devices must be working as well for vtec to engage
Old Mar 22, 2004 | 09:57 AM
Default Re: VTEC Solonoid bad? Vtec engages, then dis-engages, the engages... (autoengineer07)
everything else seems to be running fine. thanks for the help guys...
Do the solonoids go bad all at once, or do they "wear" out?
Old Mar 22, 2004 | 11:31 AM
nolimits's Avatar
I would say it's an oil pressure issue
Old Mar 23, 2004 | 04:54 AM
Default Re: VTEC Solonoid bad? Vtec engages, then dis-engages, the engages... (nolimits)
It was in fact an oil pressure issue...thanx everyone
MrRealityman
Apr 28, 2006 08:16 AM
AXZ NYC
Feb 13, 2005 09:07 AM
xvracing
May 1, 2004 01:49 PM
gsrhatch530
Mar 28, 2002 01:36 PM
